We use a keycloak public client as front end to work with the applications. This client has under “advanced settings” in keycloak the parameters:
Access Token Lifespan=3 Minutes, Client Session Idle=30 Minutes
The other fields are left empty
We tried lot of things but refresh token does not work. Could somebody tell me, what is wrong?
Thank you
How did you prove that? BTW: you have Revoke Refresh Token: ON - it means that the offline token once used will be immediately revoked = it means that refresh tokens have a one time use only
Das is right. I forget to write, that under “OpenID Connect Compatibility ModesOpenID Connect Compatibility Modes” from the client, the parameter Use Refresh Tokens = ON
From the keycloak 12.0.4 documentation, i read that Revoke Refresh Token : ON was set because of performance issue. So we leave it unchanged.
Thank you
¯\(ツ)/¯ good question should provide How to create a Minimal, Reproducible Example - Help Center - Stack Overflow Authentication topic is huge and I really don’t know what and how are doing ¯\(ツ)/¯. So again: How did you prove that refresh token does not work? It is not generated, it is not valid, it has unexpected form, it is not working only for some flows, …?
Please save time and provide reproducible example otherwise it is a guess game. Unfortunately, there is no many people with the time to play guess game what is wrong on your side.
Sorry for your time.
Hier is the code we use for refresh token in our front end. Call to keycloak.updateToken() works correctly and repeatedly, it could refresh from one time to 50 or more in a row, but sometimes it never refreshes or unexpectedly fails after few successfully refreshes (so the code in catch is executed)
@Tiekisse_ami Why would you always refresh the token automatically on the frontend without the user still needing it? This way the user is going to stay logged in even if he is no longer there.
@Edewit: Thank you for replying. I was on holiday and could not answer to your question. Without automatic refresh, the user are logged out even though if they are working. So data which are not save went lost. Client session idle time is set and we believe that the refresh does not work, if the user are not working. Is das not correct?
@Tiekisse_ami right now you are waiting on an event to trigger and then you renew this way you don’t know if the user is still actively using your application. Better would be that every time you do a request to the backend you check if the token is still valid and renew it.
@edewit: Yes, checking and refreshing the token only when then user is active could be an option but in our case he could simply be working without making a backend request and we want to refresh when the event from keycloak-js onTokenExpired fires.
when the event fires we check again and we use keycloack.update from keycloack-js to refresh it. It usually works well and refresh several times but sometimes the refresh fails.
Okay, but that means once a user is logged in he is never logged out due to inactivity. If your app is not using the token why would you need to refresh it? Normally people refresh the token when they are doing a backend call, trying to keep the token valid like you are doing is not the way to do it.
