Hi everyone, i have a problem when deploy the Keycloak Server on AWS EKS
here is my configuration:
Deployment.yaml
apiVersion: apps/v1 kind: Deployment metadata: name: my-keycloak spec: replicas: 1 selector: matchLabels: app: my-keycloak template: metadata: labels: app: my-keycloak spec: containers: - name: my-keycloak image: jboss/keycloak imagePullPolicy: IfNotPresent ports: - containerPort: 8080 name: http - containerPort: 8443 name: https env: - name: PROXY_ADDRESS_FORWARDING value: "true"
Service.yaml
apiVersion: v1 kind: Service metadata: name: my-keycloak spec: selector: app: my-keycloak ports: - port: 8080 targetPort: 8080 name: http
Ingress.yaml
apiVersion: extensions/v1beta1 kind: Ingress metadata: labels: app: my-keycloak name: my-keycloak-ingress spec: rules: - host: mykecloak.com http: paths: - backend: serviceName: my-keycloak servicePort: 8080
but the base url always set to this, which is false and not work. What i want that the base url should be https://mykeycloak.com/* (with https and without the port number)
Many people said that the solution is set the PROXY_ADDRESS_FORWARDING to TRUE, but it doesnot work for me. Is there something i miss ?
Thanks for your help
