Can anyone provide me how to configure external postgres Database connection URL in docker.
and share your yml file format for that.
Thanking you
Thanking you
Is this what you’re looking for? Or do you want it to connect to an existing postgres database that you have?
version: '3'
volumes:
postgres_data:
driver: local
services:
postgres:
image: postgres:11
volumes:
- postgres_data:/var/lib/postgresql/data
environment:
POSTGRES_DB: keycloak
POSTGRES_USER: keycloak
POSTGRES_PASSWORD: password
ports:
- 5433:5432
keycloak:
image:jboss/keycloak:latest
environment:
DB_VENDOR: POSTGRES
DB_ADDR: postgres
DB_DATABASE: keycloak
DB_USER: keycloak
DB_SCHEMA: public
DB_PASSWORD: password
KEYCLOAK_USER: admin
KEYCLOAK_PASSWORD: password
KEYCLOAK_LOGLEVEL: DEBUG
ROOT_LOGLEVEL: DEBUG
ports:
- 8080:8080
- 8443:8443
depends_on:
- postgres
No sir this is not what i am looking for.
this is for postgres image.
Actually we are using external postgres db.
we have to connect that external postgres db to keycloak.
Please provide me yml file. how we can integrate external postgres db in keycloak using yml file
For an external database, you use DB_ADDR
and DB_PORT
params. Full documentation on the parameters is here: Docker Hub
Thanking You
Can you suggest the change needed to refer the postgres Connetcion URL
instead of postgres image.
I tried removing the Postgres and depends_on section from services and passed the Database connection details in Kecyloak environment section in yaml but it did not worked for me.
