Hello all, I am trying to add a user storage provider JAR file to a KeyCloak.x instance. I am getting the following error when running ./kc.sh config:
ERROR: Build failure: Build failed due to errors
[error]: Build step io.quarkus.hibernate.orm.deployment.HibernateOrmProcessor#build threw an exception: java.lang.LinkageError: loader constraint violation: loader io.quarkus.bootstrap.classloading.QuarkusClassLoader @2eae8e6e wants to load interface org.hibernate.boot.archive.scan.spi.Scanner. A different interface with the same name was previously loaded by java.net.URLClassLoader @954b04f. (org.hibernate.boot.archive.scan.spi.Scanner is in unnamed module of loader java.net.URLClassLoader @954b04f, parent loader 'app')
Attempts made to resolve this:
- Added the following to keycloak.properties
quarkus.class-loading.parent-first-artifacts=org.hibernate:hibernate-core
- Verified that the user storage SPI and keycloak.x were using the same version of org.hibernate:hibernate-core. Version in use is 5.1.29.Final.
Is there something Iām missing here?
