I successfully added Azure AD as IdP for Keycloak and can successfully login and complete the authentication flow and user can access web app after SSO authentication.
I am trying to implement a “claim to role” mapper for the IdP and need to check if user’s AD Groups contain a particular Group GUID.
My questions are:
where is this Group GUID found in the Azure AD portal?
Is there a PowerShell or CMD command that can be run to displayed AD group memberships with/without the GUIDs?
Since authentication flow is successful, is there a way to peek/review the Groups claim in the Keycloak token and if so, how? Or can this claim detail be shown in Keycloak log?
Thanks Niko. I already had a “claim to role” mapper created but wasn’t sure where to ask my Azure DevOps to look for the group’s GUID. Thanks for the “object id” screenshot.
Besides looking at the Azure portal, is there no other way to use powershell command to look at which groups I belong to, and what their GUIDs are? I find this portal method very “unscriptable”.
I also vaguely recall, that if one can inspect the detail claims payload coming from Azure SSO to Keycloak, but I lost my notes on how to do inspect the token/claims in keycloak.
I don‘t know about powershell nor azure api, as i don‘t use it regularly. Of course there is a way via an api available, that‘s how cloud works. But this is a Keycloak forum, so you better ask somewhere where azure folks are around.
As mentioned, one of the question was, how does one can look into the token/claims detail in Keycloak? I am sure Keycloak has received a collection of groups GUIDs and based on the define “claim to role” mapper, comparing each one of them.
In Keycloak, does anyone know how to inspect the claim payload after user completed authentication from SSO?.
