Hello together,
I noticed a strange behaviour when obtaining permissions. Firstly, I shared a resource as a resource owner with a different user via the following:
curl -X POST \
http://${host}:${port}/auth/realms/${realm_name}/authz/protection/permission/ticket \
-H 'Authorization: Bearer '$access_token \
-H 'Content-Type: application/json' \
-d '{
"resource": "{resource_id}",
"requester": "{user_id}",
"granted": true,
"scopeName": "view"
Now, when obtaining permissions as the user who receives the shared resource I get two different results, depending on using the Resource Name or the Resource ID in the permissions parameter, to obtain permissions without a ticket. I use the following to obtain permissions one time with Resource ID in the permissions parameter and one time with Resource Name (following is example with Resource ID):
curl --location --request POST 'http://localhost:8080/auth/realms/proceed/protocol/openid-connect/token' \
--header 'Authorization: Bearer '$access_token \
--header 'Content-Type: application/x-www-form-urlencoded' \
--data-urlencode 'grant_type=urn:ietf:params:oauth:grant-type:uma-ticket' \
--data-urlencode 'audience=proceed-ms-backend' \
--data-urlencode 'permission=96a038cc-5b48-41fe-a38d-ac4fc0ef7885#delete' \
--data-urlencode 'response_mode=permissions'
When using the Resource ID I get the expected result:
"error": "access_denied",
"error_description": "not_authorized"
However, when using the Resource Name I get the following result:
"scopes": [
"view",
"edit",
"delete"
"rsid": "96a038cc-5b48-41fe-a38d-ac4fc0ef7885",
"rsname": "Deployment"
Unfortunately, I always get the full available scopes for a resource, when using the Resource Name. Now I could just use the Resource ID but for my use cases it would be a lot better to use the Resource Name, because using the Resource ID would require some workarounds.
For example, I have an Express.js server, that protects resources via policy enforcing through the Node.js Keycloak-Connect library. It expects the following syntax: keycloak.enforcer('{Resource}:{Scope}')
, where I need to use the Resource Name for {Resource}
. However, I only get the expected result when using the Resource ID.
Additionally, I think the documentation (Authorization Services Guide) is odd. When obtaining permissions with the permissions parameter the documentation says, to use it as RESOURCE_ID#SCOPE_ID. When using the Scope ID it doesn’t work at all and from the documentation I would expect, that it only works with Resource ID. However, it seems to work with Resource Name too but apparently returns the wrong result, as described earlier.
Obtaining permissions by a ticket instead works when using Resource Names and it also seems to work with resources, that a user has access to via policies and permissions. Maybe there is only something wrong with shared permissions by a ticket?
It would be really useful for me to have this working with Resource Names, so am I doing something wrong or is this really a bug?
Kind regards,
Kevin
