Hi!
I have several days trying to configure Keycloak 12.0.4 to work with a separated cache instance of Infinispan 11.0.4, i barely found a few tutorials but always for different versions of KC an ISPN. I have already configured both pods, the infinispan instance runs without any problem but when i try to run the Keycloak server im always getting this message:
10:22:15,537 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 63) WFLYCLINF0002: Started authenticationSessions cache from keycloak container
10:22:15,565 INFO [org.infinispan.HOTROD] (blocking-thread--p9-t1) ISPN004021: Infinispan version: Infinispan 'Corona Extra' 11.0.4.Final
10:22:15,584 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004006: Server sent new topology view (id=1, age=0) containing 1 addresses: [x.x.x.x:11222]
10:22:15,585 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004014: New server added(x.x.x.x:11222), adding to the pool.
10:22:15,587 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004016: Server not in cluster anymore(infinispan-server:11222), removing from the pool.
10:22:15,600 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 58) WFLYCLINF0002: Started sessions cache from keycloak container
10:22:15,624 INFO [org.infinispan.HOTROD] (blocking-thread--p9-t1) ISPN004021: Infinispan version: Infinispan 'Corona Extra' 11.0.4.Final
10:22:15,642 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004006: Server sent new topology view (id=1, age=0) containing 1 addresses: [x.x.x.x:11222]
10:22:15,643 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004014: New server added(x.x.x.x:11222), adding to the pool.
10:22:15,649 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004016: Server not in cluster anymore(infinispan-server:11222), removing from the pool.
10:22:15,702 INFO [org.infinispan.HOTROD] (blocking-thread--p9-t1) ISPN004021: Infinispan version: Infinispan 'Corona Extra' 11.0.4.Final
10:22:15,720 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004006: Server sent new topology view (id=1, age=0) containing 1 addresses: [x.x.x.x:11222]
10:22:15,727 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004014: New server added(x.x.x.x:11222), adding to the pool.
10:22:15,729 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004016: Server not in cluster anymore(infinispan-server:11222), removing from the pool.
10:22:15,744 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 61) WFLYCLINF0002: Started loginFailures cache from keycloak container
10:22:15,806 INFO [org.infinispan.HOTROD] (blocking-thread--p9-t1) ISPN004021: Infinispan version: Infinispan 'Corona Extra' 11.0.4.Final
10:22:15,905 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004006: Server sent new topology view (id=1, age=0) containing 1 addresses: [x.x.x.x:11222]
10:22:15,905 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004014: New server added(x.x.x.x:11222), adding to the pool.
10:22:15,920 INFO [org.infinispan.HOTROD] (Thread-0) ISPN004016: Server not in cluster anymore(infinispan-server:11222), removing from the pool.
10:22:15,949 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 60) WFLYCLINF0002: Started clientSessions cache from keycloak container
10:22:15,958 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 66) WFLYCLINF0002: Started actionTokens cache from keycloak container
This message repeats for each cache ()
Ive already checked and the IP address is OK (replaced with x.x.x.x) and i can telnet from other pods to infinispan, i dont know if im missing some configuration steps.
If any of you can help me with examples, documentation, or direct help i will really appreciate that!
EDIT:
Services:
apiVersion: v1
kind: Service
metadata:
namespace: dnoticias
annotations:
prometheus.deckhouse.io/port: "11222"
prometheus.deckhouse.io/sample-limit: "5000"
labels:
prometheus.deckhouse.io/custom-target: infinispan
app: infinispan-server
spec:
ports:
- name: http
port: 80
protocol: TCP
targetPort: http
- name: rest
port: 8080
protocol: TCP
targetPort: 8080
- name: console
port: 11222
protocol: TCP
targetPort: 11222
selector:
sessionAffinity: None
type: ClusterIP
# Headless configuration used in keycloak instances to discover each other via DNS port 7600
apiVersion: v1
kind: Service
metadata:
labels:
app.kubernetes.io/component: headless
spec:
clusterIP: None
ports:
- name: jgroups
port: 7600
protocol: TCP
targetPort: 7600
- name: jgroups1
port: 7800
protocol: TCP
targetPort: 7800
- name: jgroups2
port: 7900
protocol: TCP
targetPort: 7900
selector:
type: ClusterIP
apiVersion: v1
kind: Service
metadata:
spec:
ports:
- nodePort: 32705
port: 11222
targetPort: 11222
protocol: TCP
type: NodePort
selector:
apiVersion: v1
kind: Service
metadata:
spec:
ports:
- nodePort: 32710
port: 11222
targetPort: 11222
protocol: TCP
type: NodePort
selector:
