Configuring KeyCloak with React
I am trying to setup a Keycloak based authentication for our React app.
I have come across the following keycloak-js example. The repo contains static html pages
Gitrepo with example: GitHub - KernelFrenzy/react-keycloak: Working React Keycloak example
I could click on the following login page and was successfully logged in.
But after getting redirected to the home page, I am seeing that authentication is not successful. When I try to click on the login button to try a second login, I get the following redirects but I was never redirected to keycloak.
Not sure if anyone has come across such issue using the keycloak-js library.
Make sure the version of the keycloak-js library the example is using is the same version of the Keycloak server you are using.
I’m working through the same issue. Something to note: keycloak.login() is now an async function. All of the react libraries for keycloak don’t take this into account. You’ll need to make sure you use an older version of keycloak.
If you’d like to try the react-oidc-context and oidc-client-ts libraries, checkout this sample of how to set them up with Keycloak.
