First of all, good day to all. Now, My question is the next, is it possible to use the UserStorageProviderFactory in KC17? (BTW, this is already running alright in KC16, I just updated the dependencies in my pom.xml file)
What I’m doing:
- Created a class that implements UserStorageProviderFactory and one that implements UserStorageProvider, UserLookupProvider, CredentialInputValidator, UserQueryProvider
- Created a class that implements from org.keycloak.provider.Spi
- 2 files in “resources/META-INF/services” named: org.keycloak.provider.Spi and org.keycloak.storage.UserStorageProviderFactory (with my Factory and mapper class names)
- Packed my jar using maven-assembly-plugin to include the dependencies from my custom provider and copied the jar to the “providers” folder inside KC17
- built KC using the command ./kc.sh build
If I run the command ./kc.sh show-config I can see this line:
c.provider.file.keycloak-custom-user-component.jar.last-modified = 1645896875764 (PersistedConfigSource)
Am I doing something wrong? do I have to enable something in KC17 to use a CustomUserStorageFactory? Because the servers initializes correctly, but, I can’t see my provider inside the “User Federation” screen like I do in KC16
Thanks in advance
