I have a bunch of OIDC-clients in a realm and the goal is to require users to login with 2-factor (TOTP or WebAuthN) for apps.
But the users also need to have access to the Account Console to be able to setup 2FA in the first place, so the account console must use Conditional 2FA (Condition - User Configured in flow)
So:
- Account Manager should only enforce 2FA if user has it configured
- All other clients should have 2FA enforced and deny user access until they have registered a 2FA in Acccount console.
I can solve this by creating a separate authentication flow for the account manager client which contains the Condition - User Configured and allow the user to login to account console without 2FA set up.
The problem with this is the “Cookie”-step in the both the (browser) flow for Account Console and the rest of OIDC-clients are “shared” so if a user logs in via one flow it is already logged in for the other flow as well (Single sign on, which is nice).
A user (without 2FA setup up) can bypass 2fa auth by:
- Logging into Account Console (without 2FA)
- In the same browser go to the url of one of the other clients - The user is already logged into Keycloak (Single Sign On) and the “Cookie” is shared among clients, so the user is authorized/sent back to the client without entering credentials or 2FA.
I can remove “Cookie”-step in the flow for all 2FA clients, but I would like users not to having to enter credentials more than necessary when switching between clients.
I tried experimententing with some Level-up auth flows, but I can’t figure out how/if it is at all possible to look at “Cookie”-step further down the flow based on the “Level”.
Is it possible to enforce 2FA this way? Or should it be enforced in the clients (sending acr_values and validating afterwards) instead or how is the correct way to achieve this?
