I dived into debugging the problem and realized that the cache is NOT WORKING after all. I tried to create a new realms cluster-realm through UI and then request it directly in the pods - the realm was created only in the 1st pod!
"id": "e2269ee3-bb92-4271-9fb4-a8857990ac00",
"createdTimestamp": 1681374339352,
"username": "user@two.com",
"enabled": true,
"totp": false,
"emailVerified": false,
"email": "user@two.com",
"disableableCredentialTypes": [],
"requiredActions": [],
"notBefore": 0,
"access": {
"manageGroupMembership": true,
"view": true,
"mapRoles": true,
"impersonate": true,
"manage": true
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 1926 100 1846 100 80 15603 676 --:--:-- --:--:-- --:--:-- 16322
try on 10.220.1.36
100 28 100 28 0 0 975 0 --:--:-- --:--:-- --:--:-- 1000
"error": "Realm not found."
100 1929 100 1849 100 80 15765 682 --:--:-- --:--:-- --:--:-- 16487
try on 10.220.1.101
100 28 100 28 0 0 1179 0 --:--:-- --:--:-- --:--:-- 1166
It’s very strange because pods logs with trace on org.jgroups.protocols looks fine
2023-04-13 11:28:01,804 DEBUG [org.jgroups.protocols.dns.DNS_PING] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending discovery requests to hosts [10.220.1.226:0, 10.220.1.36:0, 10.220.1.101:0] on ports [7800 .. 7800]
2023-04-13 11:28:01,804 TRACE [org.jgroups.protocols.dns.DNS_PING] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending discovery request to 10.220.1.226:7800
2023-04-13 11:28:01,804 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to 10.220.1.226:7800, src=keycloak-0-55692, size=108, headers are DNS_PING: [GET_MBRS_REQ cluster=ISPN initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,804 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: looping back message [keycloak-0-55692 to 10.220.1.226:7800, 51 bytes, flags=OOB|DONT_BUNDLE|INTERNAL, transient_flags=DONT_LOOPBACK], headers are DNS_PING: [GET_MBRS_REQ cluster=ISPN initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,804 TRACE [org.jgroups.protocols.dns.DNS_PING] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending discovery request to 10.220.1.36:7800
2023-04-13 11:28:01,804 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to 10.220.1.36:7800, src=keycloak-0-55692, size=108, headers are DNS_PING: [GET_MBRS_REQ cluster=ISPN initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,805 TRACE [org.jgroups.protocols.dns.DNS_PING] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending discovery request to 10.220.1.101:7800
2023-04-13 11:28:01,805 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to 10.220.1.101:7800, src=keycloak-0-55692, size=108, headers are DNS_PING: [GET_MBRS_REQ cluster=ISPN initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,805 TRACE [org.jgroups.protocols.TCP] (jgroups-30,keycloak-0-55692) keycloak-0-55692: received [keycloak-0-55692 to 10.220.1.226:7800, 51 bytes, flags=OOB|DONT_BUNDLE|INTERNAL, transient_flags=DONT_LOOPBACK], headers are DNS_PING: [GET_MBRS_REQ cluster=ISPN initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,805 TRACE [org.jgroups.protocols.dns.DNS_PING] (jgroups-30,keycloak-0-55692) keycloak-0-55692: received GET_MBRS_REQ from keycloak-0-55692, sending response keycloak-0-55692, name=keycloak-0-55692, addr=10.220.1.226:7800, server
2023-04-13 11:28:01,805 TRACE [org.jgroups.protocols.TCP] (jgroups-30,keycloak-0-55692) keycloak-0-55692: sending msg to keycloak-0-55692, src=keycloak-0-55692, size=111, headers are DNS_PING: [GET_MBRS_RSP cluster=null initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,805 TRACE [org.jgroups.protocols.TCP] (jgroups-30,keycloak-0-55692) keycloak-0-55692: looping back message [keycloak-0-55692 to keycloak-0-55692, 51 bytes, flags=OOB|DONT_BUNDLE|INTERNAL], headers are DNS_PING: [GET_MBRS_RSP cluster=null initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,806 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-0-55692 to keycloak-0-55692, 51 bytes, flags=OOB|DONT_BUNDLE|INTERNAL], headers are DNS_PING: [GET_MBRS_RSP cluster=null initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,806 TRACE [org.jgroups.protocols.dns.DNS_PING] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received GET_MBRS_RSP from keycloak-0-55692: keycloak-0-55692, name=keycloak-0-55692, addr=10.220.1.226:7800, server
2023-04-13 11:28:01,808 TRACE [org.jgroups.protocols.TCP] (jgroups-30,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to keycloak-0-55692, 51 bytes, flags=OOB|DONT_BUNDLE|INTERNAL], headers are DNS_PING: [GET_MBRS_RSP cluster=null initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,808 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to 10.220.1.226:7800, 0 bytes, flags=INTERNAL], headers are MERGE3: INFO: view_id=[keycloak-2-24966|26], logical_name=keycloak-2-24966, physical_addr=10.220.1.101:7800, TP: [cluster=ISPN]
2023-04-13 11:28:01,808 TRACE [org.jgroups.protocols.dns.DNS_PING] (jgroups-30,keycloak-0-55692) keycloak-0-55692: received GET_MBRS_RSP from keycloak-2-24966: keycloak-2-24966, name=keycloak-2-24966, addr=10.220.1.101:7800, coord
2023-04-13 11:28:01,808 TRACE [org.jgroups.protocols.TCP] (jgroups-30,keycloak-0-55692) keycloak-0-55692: sending msg to 10.220.1.101:7800, src=keycloak-0-55692, size=95, headers are MERGE3: INFO: view_id=[keycloak-2-24966|26], logical_name=keycloak-0-55692, physical_addr=10.220.1.226:7800, TP: [cluster=ISPN]
2023-04-13 11:28:01,808 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to 10.220.1.226:7800, 0 bytes, flags=INTERNAL], headers are MERGE3: INFO: view_id=[keycloak-2-24966|26], logical_name=keycloak-1-48535, physical_addr=10.220.1.36:7800, TP: [cluster=ISPN]
2023-04-13 11:28:01,808 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to keycloak-0-55692, 51 bytes, flags=OOB|DONT_BUNDLE|INTERNAL], headers are DNS_PING: [GET_MBRS_RSP cluster=null initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:01,808 TRACE [org.jgroups.protocols.dns.DNS_PING] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received GET_MBRS_RSP from keycloak-1-48535: keycloak-1-48535, name=keycloak-1-48535, addr=10.220.1.36:7800, server
2023-04-13 11:28:01,808 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to 10.220.1.36:7800, src=keycloak-0-55692, size=95, headers are MERGE3: INFO: view_id=[keycloak-2-24966|26], logical_name=keycloak-0-55692, physical_addr=10.220.1.226:7800, TP: [cluster=ISPN]
2023-04-13 11:28:02,676 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to 10.220.1.226:7800, 51 bytes, flags=OOB|DONT_BUNDLE|INTERNAL], headers are DNS_PING: [GET_MBRS_REQ cluster=ISPN initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:02,677 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to 10.220.1.101:7800, src=keycloak-0-55692, size=95, headers are MERGE3: INFO: view_id=[keycloak-2-24966|26], logical_name=keycloak-0-55692, physical_addr=10.220.1.226:7800, TP: [cluster=ISPN]
2023-04-13 11:28:02,677 TRACE [org.jgroups.protocols.dns.DNS_PING] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received GET_MBRS_REQ from keycloak-2-24966, sending response keycloak-0-55692, name=keycloak-0-55692, addr=10.220.1.226:7800, server
2023-04-13 11:28:02,677 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to keycloak-2-24966, src=keycloak-0-55692, size=111, headers are DNS_PING: [GET_MBRS_RSP cluster=null initial_discovery=false], TP: [cluster=ISPN]
2023-04-13 11:28:02,679 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to 10.220.1.226:7800, 0 bytes, flags=INTERNAL], headers are MERGE3: INFO: view_id=[keycloak-2-24966|26], logical_name=keycloak-2-24966, physical_addr=10.220.1.101:7800, TP: [cluster=ISPN]
2023-04-13 11:28:03,388 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:03,388 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-1-48535
2023-04-13 11:28:04,015 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to null, src=keycloak-0-55692, size=36, headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:04,015 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sent heartbeat
2023-04-13 11:28:04,646 TRACE [org.jgroups.protocols.pbcast.STABLE] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending stable msg to keycloak-2-24966: keycloak-2-24966: [446], keycloak-1-48535: [276], keycloak-0-55692: [184]
2023-04-13 11:28:04,646 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to keycloak-2-24966, src=keycloak-0-55692, size=143, headers are STABLE: [STABLE_GOSSIP] view-id= [keycloak-2-24966|26], TP: [cluster=ISPN]
2023-04-13 11:28:04,677 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:04,677 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-2-24966
2023-04-13 11:28:05,389 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:05,389 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-1-48535
2023-04-13 11:28:06,016 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to null, src=keycloak-0-55692, size=36, headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:06,016 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sent heartbeat
2023-04-13 11:28:06,677 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:06,678 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-2-24966
2023-04-13 11:28:07,389 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:07,390 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-1-48535
2023-04-13 11:28:08,016 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to null, src=keycloak-0-55692, size=36, headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:08,016 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sent heartbeat
2023-04-13 11:28:08,566 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to <all>, 65 bytes, flags=OOB|NO_RELIABILITY|INTERNAL], headers are STABLE: [STABILITY] view-id= [keycloak-2-24966|26], TP: [cluster=ISPN]
2023-04-13 11:28:08,567 TRACE [org.jgroups.protocols.pbcast.STABLE] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received stability msg from keycloak-2-24966: keycloak-2-24966: [446], keycloak-1-48535: [276], keycloak-0-55692: [184]
2023-04-13 11:28:08,567 TRACE [org.jgroups.protocols.pbcast.NAKACK2] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received stable digest keycloak-2-24966: [446 (446)], keycloak-1-48535: [276 (276)], keycloak-0-55692: [184 (184)]
2023-04-13 11:28:08,567 TRACE [org.jgroups.protocols.pbcast.NAKACK2] (jgroups-34,keycloak-0-55692) keycloak-0-55692: deleting msgs <= 446 from keycloak-2-24966
2023-04-13 11:28:08,567 TRACE [org.jgroups.protocols.pbcast.NAKACK2] (jgroups-34,keycloak-0-55692) keycloak-0-55692: deleting msgs <= 276 from keycloak-1-48535
2023-04-13 11:28:08,567 TRACE [org.jgroups.protocols.pbcast.NAKACK2] (jgroups-34,keycloak-0-55692) keycloak-0-55692: deleting msgs <= 184 from keycloak-0-55692
2023-04-13 11:28:09,390 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:09,390 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-1-48535
2023-04-13 11:28:10,017 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to null, src=keycloak-0-55692, size=36, headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:10,017 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sent heartbeat
2023-04-13 11:28:10,678 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:10,678 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-2-24966
2023-04-13 11:28:11,391 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:11,391 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-1-48535
2023-04-13 11:28:11,863 TRACE [org.jgroups.protocols.pbcast.STABLE] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending stable msg to keycloak-2-24966: keycloak-2-24966: [446], keycloak-1-48535: [276], keycloak-0-55692: [184]
2023-04-13 11:28:11,863 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to keycloak-2-24966, src=keycloak-0-55692, size=143, headers are STABLE: [STABLE_GOSSIP] view-id= [keycloak-2-24966|26], TP: [cluster=ISPN]
2023-04-13 11:28:12,017 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to null, src=keycloak-0-55692, size=36, headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:12,018 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sent heartbeat
2023-04-13 11:28:12,679 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:12,679 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-2-24966
2023-04-13 11:28:13,391 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:13,392 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-1-48535
2023-04-13 11:28:14,018 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to null, src=keycloak-0-55692, size=36, headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:14,018 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sent heartbeat
2023-04-13 11:28:14,031 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to <all>, 65 bytes, flags=OOB|NO_RELIABILITY|INTERNAL], headers are STABLE: [STABILITY] view-id= [keycloak-2-24966|26], TP: [cluster=ISPN]
2023-04-13 11:28:14,031 TRACE [org.jgroups.protocols.pbcast.STABLE] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received stability msg from keycloak-2-24966: keycloak-2-24966: [446], keycloak-1-48535: [276], keycloak-0-55692: [184]
2023-04-13 11:28:14,031 TRACE [org.jgroups.protocols.pbcast.NAKACK2] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received stable digest keycloak-2-24966: [446 (446)], keycloak-1-48535: [276 (276)], keycloak-0-55692: [184 (184)]
2023-04-13 11:28:14,031 TRACE [org.jgroups.protocols.pbcast.NAKACK2] (jgroups-34,keycloak-0-55692) keycloak-0-55692: deleting msgs <= 446 from keycloak-2-24966
2023-04-13 11:28:14,031 TRACE [org.jgroups.protocols.pbcast.NAKACK2] (jgroups-34,keycloak-0-55692) keycloak-0-55692: deleting msgs <= 276 from keycloak-1-48535
2023-04-13 11:28:14,031 TRACE [org.jgroups.protocols.pbcast.NAKACK2] (jgroups-34,keycloak-0-55692) keycloak-0-55692: deleting msgs <= 184 from keycloak-0-55692
2023-04-13 11:28:15,392 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:15,392 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-1-48535
2023-04-13 11:28:16,018 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to null, src=keycloak-0-55692, size=36, headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:16,019 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sent heartbeat
2023-04-13 11:28:16,679 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:16,679 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-2-24966
2023-04-13 11:28:17,393 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:17,393 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-1-48535
2023-04-13 11:28:18,019 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sending msg to null, src=keycloak-0-55692, size=36, headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:18,019 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: sent heartbeat
2023-04-13 11:28:18,680 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-2-24966 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:18,680 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-2-24966
2023-04-13 11:28:19,394 TRACE [org.jgroups.protocols.TCP] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received [keycloak-1-48535 to <all>, 0 bytes, flags=INTERNAL], headers are FD_ALL: heartbeat, TP: [cluster=ISPN]
2023-04-13 11:28:19,394 TRACE [org.jgroups.protocols.FD_ALL] (jgroups-34,keycloak-0-55692) keycloak-0-55692: received heartbeat from keycloak-1-48535
