I’m using Spring Boot and Keycloak and I want to customize the 404 - Not found error page and the 500 - Internal Server Error.
I have overwritten KeycloakWebSecurityConfigurerAdapter and the method keycloakAuthenticationProcessingFilter to setup a custom AuthenticationFailureHandler.
@Bean
@Override
protected KeycloakAuthenticationProcessingFilter keycloakAuthenticationProcessingFilter() throws Exception {
KeycloakAuthenticationProcessingFilter filter =
new McdKeycloakAuthenticationProcessingFilter(authenticationManagerBean(), requestMatcher);
filter.setSessionAuthenticationStrategy(sessionAuthenticationStrategy());
filter.setAuthenticationFailureHandler(this.mcdKeycloakAuthenticationFailureHandler);
filter.setAuthenticationSuccessHandler(this.mcdAuthenticationSuccessHandler);
return filter;
And my AuthenticationFailureHandler looks like
@Component
public class McdKeycloakAuthenticationFailureHandler extends KeycloakAuthenticationFailureHandler {
private static final Logger LOGGER = LoggerFactory.getLogger(McdKeycloakAuthenticationFailureHandler.class);
@Autowired
DefaultErrorHandler defaultErrorHandler;
@Override
public void onAuthenticationFailure(HttpServletRequest request, HttpServletResponse response,
AuthenticationException exception) throws IOException, ServletException {
LOGGER.debug("onAuthenticationFailure {}", exception.toString());
// Check that the response was not committed yet (this may happen when another
// part of the Keycloak adapter sends a challenge or a redirect).
if (!response.isCommitted()) {
if (KeycloakCookieBasedRedirect.getRedirectUrlFromCookie(request) != null) {
response.addCookie(KeycloakCookieBasedRedirect.createCookieFromRedirectUrl(null));
defaultErrorHandler.handleCommonException(HttpStatus.UNAUTHORIZED, exception);
} else {
LOGGER.debug("onAuthenticationFailure - response isCommitted - Status: {}", response.getStatus());
if (200 <= response.getStatus() && response.getStatus() < 300) {
throw new RuntimeException("Success response was committed while authentication failed!", exception);
However, I’m not able to set a custom response for 404/500 since the response is already committed at this point.
Do you know how to return a custom error page/response for these errors ?
