I am integrating a pretty old school AIM system into keycloak and for this have a custom user storage provider and an associated mapper.
Ultimately what I do is a custom login and upon that login I have two properties I want to put into the token so I want to be able to communicate these between my user storage provider and my mapper.
I was doing this via user attributes however it appears to be the wrong way to do things as the user attributes are stored when the user is first retrieved and then are immutable. I would have liked to do this via the session but the mapper and the user storage provider do not seem to share the same session.
I have a feeling I am missing something fundamental here… Any advice on whether at a high level the above approach seems sound and if so what is the normal etiquette when communicating data between the user storage provider and a mapper? The data will change per login so needs to be mutable.
I’m not sure this is the case, because some user storage providers like the Ldap provider do import new user attributes. You could take a look at it to see the behavior.
I found something interesting wrt sessions. If in the user storage provider in the create method I add an attribute to the session then the mapper can pick it up whereas if I add an attribute in my isValid credentialsValidator function (same object) then it doesn’t get picked up by the protocol mapper. I added a UUID to the object to verify they’re both the same and sure enough they are. Logging suggests that the values are added before the mapper is called so I am unsure how the session isn’t able to pick up these attributes. Ideally I would just place a couple of values in the session but for some reason that is not working.
The user attributes stuff is my fallback from session not working which tbh I am guessing I won’t be able to solve. It seems like a simple enough problem with which I feel I am just missing something obvious!
Yeah it pretty much is tricking me. I’m looking into this LDAP stuff now.
I also don’t understand why the session is not retaining values from the isValid credentialsInput function.
I have tried removing the user from local store on a per login basis but a) it doesn’t work… and b) it feels like a bit of hack so I’m not sure it’s the greatest idea…
Ideally I didn’t want to persist any kind of user data at all but it seems to be under the hood stuff is stored over and above the session.
