I’m trying to understand the keycloak implementation in our company but I have no idea how it works, because there is no documentation.
Further I don’t find good keycloak resources/documentation to understand its behavior.
Currently we use an external oauth2/openid auth server for login. It’s configured at “identity provider”.
If I login into our application I enter the keycloak login page for the login. And in the network tab I see multiple oauth2 processes.
My question are:
- Are there 2 oauth2 login proccesses active? One between client (vue application) and keycloak and one between keycloak and the identity provider?
When I configure keycloak I set “clients” and “scopes”. That looks like keycloak is a oauth2 auth server itself. - If the idententy provider disables the option “store token” the identity provider will never be used again for a user after he logged in?
Maybe you could provide me some documentation which I can read to understand the behavior of keycloak while the login proccess.
T
