I’m learning KeyCloak, and I’m currently integrating official secret question examples.
I have placed the compiled JAR package in the /provider directory and executed the ${kc.home.dir}/bin/kc.sh build command.I then reopened KeyCloak and was able to select secret question from the authentication stream.
But when I connect my client link and automatically jump to the Keycloak authentication page, I get the following error:
Invalid username or password.
server error logs:
2022-08-11 23:34:54,669 WARN [org.keycloak.authentication.DefaultAuthenticationFlow] (executor-thread-44) REQUIRED and ALTERNATIVE elements at same level! Those alternative executions will be ignored: [auth-cookie, identity-provider-redirector]
2022-08-11 23:34:54,670 WARN [org.keycloak.services] (executor-thread-44) KC-SERVICES0013: Failed authentication: org.keycloak.authentication.AuthenticationFlowException: authenticator: secret-question-authenticator
at org.keycloak.authentication.DefaultAuthenticationFlow.processSingleFlowExecutionModel(DefaultAuthenticationFlow.java:423)
at org.keycloak.authentication.DefaultAuthenticationFlow.processFlow(DefaultAuthenticationFlow.java:250)
at org.keycloak.authentication.AuthenticationProcessor.authenticateOnly(AuthenticationProcessor.java:1017)
at org.keycloak.authentication.AuthenticationProcessor.authenticate(AuthenticationProcessor.java:879)
at org.keycloak.protocol.AuthorizationEndpointBase.handleBrowserAuthenticationRequest(AuthorizationEndpointBase.java:151)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.buildAuthorizationCodeAuthorizationResponse(AuthorizationEndpoint.java:338)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.process(AuthorizationEndpoint.java:194)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.buildGet(AuthorizationEndpoint.java:112)
at jdk.internal.reflect.GeneratedMethodAccessor479.invoke(Unknown Source)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:90)
at io.quarkus.vertx.core.runtime.VertxCoreRecorder$13.runWith(VertxCoreRecorder.java:545)
2022-08-11 23:34:54,679 WARN [org.keycloak.events] (executor-thread-44) type=LOGIN_ERROR, realmId=ca7ca487-f63a-4ba1-ab7f-c95b9f4f04a3, clientId=app-authz-vanilla, userId=null, ipAddress=172.20.25.22, error=invalid_user_credentials, auth_method=openid-connect, auth_type=code, response_type=code, redirect_uri=http://172.20.25.22:8081/getUserInfo, code_id=827be7e0-b798-4008-8eb0-561ff1e6288f, response_mode=query, authSessionParentId=827be7e0-b798-4008-8eb0-561ff1e6288f, authSessionTabId=kS_EC6JoUdY
My authentication flow is configured as follows
My client configuration is as follows
keycloak:
# public-client: true
realm: hello-world-auth-test
auth-server-url: http://10.30.51.30:8080/
ssl-required: none
resource: app-authz-vanilla
verify-token-audience: true
# use-resource-role-mappings: true
credentials:
secret: YTeBZRQyYuXYN5wEI1vkl6XNrconYo1b
confidential-port: 0
security-constraints:
- #logout
securityCollections:
- name: logout
patterns:
- /logout
- # roles
authRoles:
- admin
patterns:
- /admin/*
- /system/*
- # test
authRoles:
- admin
- user
- name: user
patterns:
- /test/*
- /getUserInfo
- /custom-resource/*
- My Keycloak version is 19.0.1
