we are looking for some advice on how to use an access token within a long running background process that exceeds the token expiry. We are using Keycloak with OpenId Connect and we would like to stick to the standard. Maybe bend it a little bit, if necessary, but not overthrow it.
Use-Case:
User calls a service with his access token. The service starts a long running background process that calls other services. The access token is being sent to the other services in order to authorize the request and relate the action to the user (e.g. “changed by”). The background process may take days or even weeks.
Any ideas? Thanks in advance!
