I’m trying to set a quarkus configuration, but I can not find any trace of the property actually being used.
I’ve tried with setting-Dquarkus.datasource.jdbc.max-lifetime=12H
in JAVA_OPTS
and/or quarkus.datasource.jdbc.max-lifetime=12H
in conf/quarkus.properties
but I can’t find any trace of it actually being set in the logs or anything.
How can I verify that the configuration is actually used? Or am I not doing as intended? Followed the documentation here.
Also created in issue if this should be keycloak server configuration, here.
