Hi Everybody, new to KeyCloak and I installed the latest version on a AWS EC2 (Windows Server 2022) instance. Everything was going pretty well until (I knew I’d get locked out…) I enabled Require SSL to ‘All’ from ‘External only’ or whatever the default value is. I did have a valid certificate (web server & kerberos) certificate installed on the EC2 instance where KeyCloak was running (verified bindings in IIS) but I’m not fairly certain KeyCloak doesn’t utilize the Windows certificate store (nor IIS)…
Anyways, I can no longer access my admin console (master realm) and was wondering if there’s anyway to restore or uninstall/reinstall (reset to factory) settings to I can go back to configuring??
THANKS!
