When I use “userAccount”: “true” in the REST call for get users it does not filter on that attribute on the user. The attribute is userAccount and true for the value
Is there something I am missing? Is the syntax I am using wrong? Is there an additional setting for a client that needs to be used?
Specifically from the 16.1 documentation
query q optional A query to search for custom attributes, in the format ‘key1:value2 key2:value2’ string
Which I assume lines up with:
Public static final SearchableModelField ATTRIBUTE = new SearchableModelField<>(“attribute”, String[].class);
