when i tried to validate JWT token sometimes i get an “Signature validation failed.” and again tried to same token, When I try again, token validation is successful. This problem happens all the time. Validation method is below. If anyone has experienced this situation before, can they give an idea about the solution?
var rsaParameters = new RSAParameters
Modulus = Base64UrlEncoder.DecodeBytes(keys[0]["n"].ToString()),
Exponent = Base64UrlEncoder.DecodeBytes(keys[0]["e"].ToString())
using var rsa = RSA.Create();
rsa.ImportParameters(rsaParameters);
var validationParameters = new TokenValidationParameters
ValidateIssuerSigningKey = true,
IssuerSigningKey = new RsaSecurityKey(rsa),
ValidateIssuer = false,
ValidateAudience = false
var tokenHandler = new JwtSecurityTokenHandler();
tokenHandler.ValidateToken(_token, validationParameters, out _);
