Invalid Requester with Slack SAML provider
Hey all trying to setup slack with saml using the a local keycloak server for a poc. I have a client for slack setup.
after I add the configuration to slack I get an invalid requester and from the logs I get this following error?
2023-02-21 23:04:06,085 ERROR [org.keycloak.protocol.saml.SamlService] (executor-thread-0) request validation failed: org.keycloak.common.VerificationException: java.security.SignatureException: Signature length not correct: got 512 but was expecting 256
	at org.keycloak.protocol.saml.SamlProtocolUtils.verifyRedirectSignature(SamlProtocolUtils.java:189)
	at org.keycloak.protocol.saml.SamlProtocolUtils.verifyRedirectSignature(SamlProtocolUtils.java:147)
	at org.keycloak.protocol.saml.SamlService$RedirectBindingProtocol.verifySignature(SamlService.java:765)
	at org.keycloak.protocol.saml.SamlService$BindingProtocol.handleSamlRequest(SamlService.java:303)
	at org.keycloak.protocol.saml.SamlService$BindingProtocol.execute(SamlService.java:690)
	at org.keycloak.protocol.saml.SamlService.redirectBinding(SamlService.java:817)
	at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1284)
	at io.vertx.ext.web.impl.RoutingContextImplBase.iterateNext(RoutingContextImplBase.java:173)
	at io.vertx.ext.web.impl.RoutingContextImpl.next(RoutingContextImpl.java:140)
	at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:84)
	at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:71)
	at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:430)
	at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:408)
	at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$0(QuarkusRequestFilter.java:82)
	at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:576)
Caused by: java.security.SignatureException: Signature length not correct: got 512 but was expecting 256
	at java.base/sun.security.rsa.RSASignature.engineVerify(RSASignature.java:212)
	at java.base/java.security.Signature$Delegate.engineVerify(Signature.java:1416)
	at java.base/java.security.Signature.verify(Signature.java:790)
	at org.keycloak.protocol.saml.SamlProtocolUtils.verifyRedirectSignature(SamlProtocolUtils.java:185)
	... 51 more
