Hi all,
I’m very new to KeyCloak and wanted to get my hands dirty over this. While following the documentation of configuring the server and after executing kc.bat start-dev I am getting errors. I guess I am missing something to add in the conf file but I am unable to figure it out. Any assistance is widely appreciated. Thanks!
Errors
2024-06-25 18:59:20,041 INFO [org.keycloak.quarkus.runtime.hostname.DefaultHostnameProvider] (main) Hostname settings: Base URL: , Hostname: localhost, Strict HTTPS: false, Path: , Strict BackChannel: false, Admin URL: , Admin: , Port: -1, Proxied: false
2024-06-25 18:59:21,843 WARN [org.infinispan.CONFIG] (keycloak-cache-init) ISPN000569: Unable to persist Infinispan internal caches as no global state enabled
2024-06-25 18:59:22,138 INFO [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000556: Starting user marshaller ‘org.infinispan.jboss.marshalling.core.JBossUserMarshaller’
2024-06-25 18:59:29,617 WARN [io.quarkus.agroal.runtime.DataSources] (JPA Startup Thread) Datasource enables XA but transaction recovery is not enabled. Please enable transaction recovery by setting quarkus.transaction-manager.enable-recovery=true, otherwise data may be lost if the application is terminated abruptly
2024-06-25 18:59:34,772 WARN [org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator] (JPA Startup Thread) HHH000342: Could not obtain connection to query metadata: java.lang.NullPointerException: Cannot invoke “org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(java.sql.SQLException, String)” because the return value of “org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.sqlExceptionHelper()” is null
at org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.doTheWork(JtaIsolationDelegate.java:186)
at org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.lambda$delegateWork$1(JtaIsolationDelegate.java:75)
at org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.doInSuspendedTransaction(JtaIsolationDelegate.java:107)
at org.hibernate.resource.transaction.backend.jta.internal.JtaIsolationDelegate.delegateWork(JtaIsolationDelegate.java:72)
at org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator.getJdbcEnvironmentUsingJdbcMetadata(JdbcEnvironmentInitiator.java:276)
at org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator.initiateService(JdbcEnvironmentInitiator.java:107)
at org.hibernate.engine.jdbc.env.internal.JdbcEnvironmentInitiator.initiateService(JdbcEnvironmentInitiator.java:68)
at org.hibernate.boot.registry.internal.StandardServiceRegistryImpl.initiateService(StandardServiceRegistryImpl.java:130)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.createService(AbstractServiceRegistryImpl.java:263)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:238)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:215)
at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.configure(JdbcServicesImpl.java:52)
at org.hibernate.boot.registry.internal.StandardServiceRegistryImpl.configureService(StandardServiceRegistryImpl.java:136)
at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:247)
at org.hibernate.boot.internal.SessionFactoryOptionsBuilder.(SessionFactoryOptionsBuilder.java:276)
at io.quarkus.hibernate.orm.runtime.recording.PrevalidatedQuarkusMetadata.buildSessionFactoryOptionsBuilder(PrevalidatedQuarkusMetadata.java:70)
at io.quarkus.hibernate.orm.runtime.boot.FastBootEntityManagerFactoryBuilder.build(FastBootEntityManagerFactoryBuilder.java:84)
at io.quarkus.hibernate.orm.runtime.FastBootHibernatePersistenceProvider.createEntityManagerFactory(FastBootHibernatePersistenceProvider.java:72)
at jakarta.persistence.Persistence.createEntityManagerFactory(Persistence.java:80)
at jakarta.persistence.Persistence.createEntityManagerFactory(Persistence.java:55)
at io.quarkus.hibernate.orm.runtime.JPAConfig$LazyPersistenceUnit.get(JPAConfig.java:157)
at io.quarkus.hibernate.orm.runtime.JPAConfig$1.run(JPAConfig.java:64)
at java.base/java.lang.Thread.run(Thread.java:1570)
2024-06-25 18:59:37,017 INFO [org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory] (main) Node name: node_858635, Site name: null
2024-06-25 18:59:37,469 WARN [io.agroal.pool] (agroal-11) Datasource ‘’: IO Exception: “C:/Users/romit.mehta/Downloads/keycloak-24.0.2/keycloak-24.0.2/data/h2/keycloakdb.mv.db” [90028-224]
2024-06-25 18:59:37,490 WARN [io.agroal.pool] (agroal-11) Datasource ‘’: Error opening database: “Sleep interrupted” [8000-224]
2024-06-25 18:59:37,604 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to start server in (development) mode
2024-06-25 18:59:37,605 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to obtain JDBC connection
2024-06-25 18:59:37,605 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Error opening database: “Sleep interrupted” [8000-224]
2024-06-25 18:59:37,606 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: sleep interrupted
2024-06-25 18:59:37,606 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) For more details run the same command passing the ‘–verbose’ option. Also you can use ‘–help’ to see the details about the usage of the particular command.
