Java + Keycloak -> token verification
I have a Java application with the following configuration:
quarkus:
oidc:
auth-server-url: http://localhost:8080/auth/realms/ar-console
client-id: ${KEYCLOAK_CLIENT_ID}
credentials:
secret: ${KEYCLOAK_CLIENT_SECRET}
Keycloak and the Java application are running on the same host.
I’m taking token from this Keycloak using Postman but using its external address e.g. http://67.239.34.22:9000
When I tryaing to get to the resource with this token, i receive status 401 Unathorized.
I don’t know why since it’s the same Keycloak server!
I remember it worked on earlier versions of Keycloak, so i suspect that something must have changed at some point.
Can someone explain to me how it is verified whether the received token was generated by the appropriate Keycloak.
One thing to keep in mind is that during the token validation, you MUST have the iss claim (issuer) with the same value. If you use different domains for the OIDC discovery endpoint and the token negotiation, the token validation will fail.
Here is the full spec of the token validation:
Regards,
