I’m getting javax.net.ssl.SSLHandshakeException when I’m testing my ldap connection authentication. There’s no problem on testing the connection url but it is failing on testing authentication.
My dockerfile:
FROM quay.io/keycloak/keycloak:latest
WORKDIR /opt/jboss/keycloak
COPY rootca.cer /opt/jboss/keycloak/standalone/configuration/ldap.cer
USER root
# RUN keytool -import -alias ldapcert -file /opt/jboss/keycloak/standalone/configuration/ldap.cer -keystore /lib/jvm/jre-17/lib/security/cacerts -storepass dummypassword-noprompt
RUN keytool -import -alias ldapcert -file /opt/jboss/keycloak/standalone/configuration/ldap.cer -keystore /opt/jboss/keycloak/standalone/configuration/key.jks -storepass dummypasword-noprompt
My docker compose:
keycloak:
container_name: keycloak
build:
context: .
dockerfile: Dockerfile.keycloak
command:
- "start"
restart: always
environment:
KC_DB: postgres
KC_DB_URL_HOST: postgres
KC_DB_URL_DATABASE: keycloak
KC_DB_PASSWORD: dummy
KC_DB_USERNAME: dummy
KC_DB_SCHEMA: public
KC_PROXY: passthrough
KEYCLOAK_ADMIN_PASSWORD: dummy
KEYCLOAK_ADMIN: dummy
KC_HOSTNAME_STRICT_BACKCHANNEL: 'false'
KC_HTTP_ENABLED: 'true'
PROXY_ADDRESS_FORWARDING: 'true'
KC_HOSTNAME_STRICT: 'false'
KC_HOSTNAME_STRICT_HTTPS: 'false'
KC_METRICS_ENABLED: 'true'
KC_HTTP_PORT: 8890
KC_HTTPS_KEY_STORE_FILE: /opt/jboss/keycloak/standalone/configuration/key.jks
KC_HTTPS_KEY_STORE_PASSWORD: dummypassword
KC_HTTPS_TRUST_STORE_FILE: /opt/jboss/keycloak/standalone/configuration/key.jks
KC_HTTPS_TRUST_STORE_PASSWORD: dummypassword
ports:
- "8890:8890"
depends_on:
- postgres
It’s seems like the truststore it not being loaded,my keycloak server logs:
`2023-04-25 18:20:24,877 ERROR [org.keycloak.services] (executor-thread-7) KC-SERVICES0055: Error when authenticating to LDAP: simple bind failed: dummyurl javax.naming.CommunicationException: simple bind failed: dummyurl [Root exception is javax.net.ssl.SSLHandshakeException: Remote host terminated the handshake]`
`at java.naming/com.sun.jndi.ldap.LdapClient.authenticate(LdapClient.java:219)`
`at java.naming/com.sun.jndi.ldap.LdapCtx.connect(LdapCtx.java:2896)`
`at java.naming/com.sun.jndi.ldap.LdapCtx.<init>(LdapCtx.java:348)`
`at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxFromUrl(LdapCtxFactory.java:229)`
`at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(LdapCtxFactory.java:189)`
`at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(LdapCtxFactory.java:247)`
`at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(LdapCtxFactory.java:154)`
`at java.naming/com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(LdapCtxFactory.java:84)`
`at java.naming/javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:732)`
`at java.naming/javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:305)`
`at java.naming/javax.naming.InitialContext.init(InitialContext.java:236)`
`at java.naming/javax.naming.ldap.InitialLdapContext.<init>(InitialLdapContext.java:154)`
`at org.keycloak.storage.ldap.idm.store.ldap.LDAPContextManager.createLdapContext(LDAPContextManager.java:80)`
`at org.keycloak.storage.ldap.idm.store.ldap.LDAPContextManager.getLdapContext(LDAPContextManager.java:101)`
`at org.keycloak.services.managers.LDAPServerCapabilitiesManager.testLDAP(LDAPServerCapabilitiesManager.java:99)`
`at org.keycloak.services.resources.admin.TestLdapConnectionResource.testLDAPConnection(TestLdapConnectionResource.java:89)`
`at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)`
`at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)`
`at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)`
`at java.base/java.lang.reflect.Method.invoke(Method.java:568)`
`at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:170)`
`at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:130)`
`at org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:660)`
`at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:524)`
`at org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$2(ResourceMethodInvoker.java:474)`
`at org.jboss.resteasy.core.interception.jaxrs.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:364)`
`at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:476)`
`at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:434)`
`at org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:192)`
`at org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:152)`
`at org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:183)`
`at org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:141)`
`at org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:32)`
`at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:492)`
`at org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:261)`
`at org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:161)`
`at org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:164)`
`at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:247)`
`at io.quarkus.resteasy.runtime.standalone.RequestDispatcher.service(RequestDispatcher.java:73)`
`at io.quarkus.resteasy.runtime.standalone.VertxRequestHandler.dispatch(VertxRequestHandler.java:151)`
`at io.quarkus.resteasy.runtime.standalone.VertxRequestHandler.handle(VertxRequestHandler.java:82)`
`at io.quarkus.resteasy.runtime.standalone.VertxRequestHandler.handle(VertxRequestHandler.java:42)`
`at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1284)`
`at io.vertx.ext.web.impl.RoutingContextImplBase.iterateNext(RoutingContextImplBase.java:173)`
`at io.vertx.ext.web.impl.RoutingContextImpl.next(RoutingContextImpl.java:140)`
`at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:84)`
`at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:71)`
`at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:430)`
`at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:408)`
`at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$0(QuarkusRequestFilter.java:82)`
`at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:576)`
`at org.jboss.threads.EnhancedQueueExecutor$Task.run(EnhancedQueueExecutor.java:2449)`
`at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1478)`
`at org.jboss.threads.DelegatingRunnable.run(DelegatingRunnable.java:29)`
`at org.jboss.threads.ThreadLocalResettingRunnable.run(ThreadLocalResettingRunnable.java:29)`
`at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30)`
`at java.base/java.lang.Thread.run(Thread.java:833)`
`Caused by: javax.net.ssl.SSLHandshakeException: Remote host terminated the handshake`
`at java.base/sun.security.ssl.SSLSocketImpl.handleEOF(SSLSocketImpl.java:1719)`
`at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1518)`
`at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1425)`
`at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:455)`
`at java.base/sun.security.ssl.SSLSocketImpl.ensureNegotiated(SSLSocketImpl.java:925)`
`at java.base/sun.security.ssl.SSLSocketImpl$AppOutputStream.write(SSLSocketImpl.java:1295)`
`at java.base/java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:81)`
`at java.base/java.io.BufferedOutputStream.flush(BufferedOutputStream.java:142)`
`at java.naming/com.sun.jndi.ldap.Connection.writeRequest(Connection.java:415)`
`at java.naming/com.sun.jndi.ldap.Connection.writeRequest(Connection.java:388)`
`at java.naming/com.sun.jndi.ldap.LdapClient.ldapBind(LdapClient.java:359)`
`at java.naming/com.sun.jndi.ldap.LdapClient.authenticate(LdapClient.java:214)`
`... 65 more`
`Caused by: java.io.EOFException: SSL peer shut down incorrectly`
`at java.base/sun.security.ssl.SSLSocketInputRecord.read(SSLSocketInputRecord.java:489)`
`at java.base/sun.security.ssl.SSLSocketInputRecord.readHeader(SSLSocketInputRecord.java:478)`
`at java.base/sun.security.ssl.SSLSocketInputRecord.decode(SSLSocketInputRecord.java:160)`
`at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:111)`
`at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1510)`
`... 75 more`2023-04-25 18:20:24,877 ERROR [org.keycloak.services] (executor-thread-7) KC-SERVICES0055: Error when authenticating to LDAP: simple bind failed:dummyurl javax.naming.CommunicationException: simple bind failed: dummyurl [Root exception is javax.net.ssl.SSLHandshakeException: Remote host terminated the handshake]
... 65 more
... 75 more
