I want to create a new realm via the java client.
Here is my code - its pretty simple - I use the quarkus keycloak client (quarkus-keycloak-admin-client)
@Dependent
public class InitKeycloak {
private static final String serverUrl = "http://localhost:8099/";
private static final String realm = "master";
private static final String username = "admin";
private static final String password = "admin";
private static final String clientId = "admin-cli";
private static final String appRealmName = "test";
public void createSimpleRealm() {
RealmRepresentation realm = new RealmRepresentation();
realm.setRealm(appRealmName);
realm.setEnabled(true);
Keycloak keycloak = KeycloakBuilder
.builder()
.serverUrl(serverUrl)
.realm("master")
.username(username)
.password(password)
.clientId(clientId)
.resteasyClient(new ResteasyClientBuilderImpl().connectionPoolSize(10).build())
.build();
keycloak.realms().create(realm);
keycloak 17 is running in a local docker container.
docker run -d -p 8099:8080 -e KEYCLOAK_ADMIN=admin -e KEYCLOAK_ADMIN_PASSWORD=admin quay.io/keycloak/keycloak:17.0.0 start-dev
The code is executed in a quarkus 2.7.1 project.
In Quarkus I get an HTTP 500 and in Keycloak I see the following error:
2022-02-18 09:54:26,562 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-44) Uncaught server error: java.lang.NullPointerException
at org.keycloak.services.managers.RealmManager.determineDefaultRoleName(RealmManager.java:610)
at org.keycloak.services.managers.RealmManager.importRealm(RealmManager.java:518)
at org.keycloak.services.managers.RealmManager.importRealm(RealmManager.java:495)
at org.keycloak.services.resources.admin.RealmsAdminResource.importRealm(RealmsAdminResource.java:133)
Can you give me a hint whats going wrong? I checked several test suites where you do the same …
Reading stuff (like realm details) works - but the realm creation fails …
Thanks Max
