(using http:// in this post)
I’m configuring a java aplication using de KC adapter (17.0.0) in Spting MVC + tomcat
when using just tomcat and keycloak without a proxy everything works…
theApp: http://localhost:8081/myTomcatContext
KC: http:–localhost:8080
the kc adapter settings are:
“realm”: “realm”,
“auth-server-url”: “http://localhost:8080/”,
“ssl-required”: “external”,
“resource”: “app-client”,
“credentials”: {
“secret”: “secret”
“confidential-port”: 0
If I request a secured resource let say http:–localhost:8081/myApp/test (without proxy)
I can log in to keycloak and once authorized I’m redirected to the resource correctly
Now I’m configuring httpd (apache) as reverse proxy with two Vhosts so
“realm”: “realm”,
“auth-server-url”: “http:–auth.myhost.local”,
“credentials”: {
“secret”: “secret”
http:–localhost:8081/myTomcatContext → http:–www.myhost.local
http:–localhost:8080 → http:–auth.myhost.local
first: when redirecting to /sso/login I need to create a rewrite rule since the request is
http:–www.myhost.local/myTomcatContext/sso/login so it is rewritten to http:–www.myhost.local/sso/login
At this point I’mreaching keycloak but… Is there a way to configure the KC adapter (or KC) and not having to add the rewrite condition?
Second: once on keycloak the redirect_uri contains http:–www.myhost.local/myTomcatContext/sso/login (again with the tomcat context) and once authorizedd I’m been redirected to http:–www.myhost.local/myTomcatContext/test.
Is there a way to spefcify the base URL? I’ve tried Base URL (in KC client) to http:–www.myhost.local/ but still the tomcat context is used
Even when requesting a resource once authorized the adapter redirects to http:–www.myhost.local/myTomcatContext/theResource
Do I need to add any special header so KC sees the app as http:–www.myhost.local and not as http:–www.myhost.local/myTomcatContext?
Thanks in advance
