I’m trying to configure IDP initiated SSO login with Okta. I found in the keycloak logs this error:
type=IDENTITY_PROVIDER_RESPONSE_ERROR, realmId=test, clientId=null, userId=null, ipAddress=xx.xx.xxx.xxx, error=invalid_saml_response, reason=invalid_destination, requestUri=http://example.com/auth/realms/test/broker/okta-button/endpoint/clients/myapp-saml
I guess this error appears because of HTTP in requestUri however I’m working with keycloak via https.
This is my configuration:
load balancer (https)--> kong --> docker --> keycloak (http)
Is it possible to fix requestUri via some parameter in jBoss/keycloak to use https instead of http?
