Hi everyone!
I am trying to dockerize an application in Spring and Keycloak with a Postgres database. This is my docker-compose.yml:
version: '3.3'
services:
score_spring_boot:
build:
context: .
dockerfile: Dockerfile
ports:
- "8080:8080"
depends_on:
- score_keycloak
networks:
- my-network
score_keycloak:
image: quay.io/keycloak/keycloak:22.0.3
container_name: score_keycloak
ports:
- "9090:8080"
environment:
DB_VENDOR: POSTGRES
DB_ADDR: score_postgres
DB_PORT: 5432
DB_DATABASE: keycloak
DB_USER: keycloak
DB_PASSWORD: admin
KEYCLOAK_ADMIN: admin
KEYCLOAK_ADMIN_PASSWORD: admin
depends_on:
- score_postgres
command:
- "start-dev"
networks:
- my-network
score_postgres:
image: postgres:latest
container_name: score_postgres
ports:
- "5432:5432"
environment:
POSTGRES_DB: keycloak
POSTGRES_USER: keycloak
POSTGRES_PASSWORD: admin
volumes:
- pg_data:/var/lib/postgresql/data
networks:
- my-network
pgadmin:
container_name: pgadmin4_container
image: dpage/pgadmin4:latest
environment:
PGADMIN_DEFAULT_EMAIL: admin@admin.com
PGADMIN_DEFAULT_PASSWORD: admin
PGADMIN_LISTEN_PORT: 80
ports:
- "5050:80"
networks:
- my-network
volumes:
pg_data:
networks:
my-network:
driver: bridge
The problem occurs when I run docker-compose and try to access a secured endpoint, I get this:
score_spring_boot-1 | org.springframework.security.authentication.AuthenticationServiceException: An error occurred while attempting to decode the Jwt: Couldn't retrieve remote JWK set: org.springframework.web.client.ResourceAccessException: I/O error on GET request for "http://localhost:9090/auth/realms/score/protocol/openid-connect/certs": Connection refused
Do I have to change in the client administration panel the server name to the container name ?
Your help would be very valuable!
