I’m running into an issue getting Keycloak to play nice in a kubernetes cluster.
Using image: jboss/keycloak:9.0.2
Fronting the pod with a service:
apiVersion: v1
kind: Service
metadata:
spec:
# selector tells Kubernetes what Deployment this Service
# belongs to
selector:
app: keycloak
ports:
# web console
- port: 8080
protocol: TCP
nodePort: 30082
type: NodePort
Can access and login to web console with no problem. Using http://devserver:30082/auth.
If I connect internally from another microservice using the service name http://keycloak-svc:8080/auth, I receive an issuer mismatch error validating tokens.
I can set the KEYCLOAK_FRONTEND_URL on the container to “http://keycloak-svc:8080/auth” which allows the token to be validated, but the admin application attempts to rewrite URLs to that internal host which isn’t addressable.
Any thoughts on how to balance both things working?
