The keycloak-js client no longer supports the ability to add a keycloak clientSecret, this means for Front End JS Apps, you can only use a Public keycloak client.
Public keycloak clients do not allow you to configure fine-grained authorization services, i.e. Resource, Scopes, Policies, Permissions.
I can only see four options.
For Front End JS clients, just accept that only simple authorization through roles is available.
Access Keycloak from the Client via an API, although for the Front End client, that means trusting something other than Keycloak, which adds security holes.
Find an alternative to Front End JS
Find an alternative to Keycloak
Am I missing something? How are others getting around this problem?
Interesting. I have the same conundrum as @simonjcarr. Since we are forced to set the access type to be public, I lose access to the Authorization tab within my client. @sharpedavid I’m curious about your setup, would you mind sharing it? Perhaps @simonjcarr and I are missing something.
I’m using version 13.0.0. However, when looking for what version I’m running I realized the ADMIN_FINE_GRAINED_AUTHZ feature is disabled for me but it also appears to be a preview feature which are disabled by default. Do you have the ADMIN_FINE_GRAINED_AUTHZ feature enabled?
Here’s my setup:
My current setup in Keycloak is as follows:
Realm: admin-service
Client: admin-service-api
Access Type: confidential (because I want to use authorization to restrict api requests according to permission levels)
Root URL: http://localhost:8080/
Valid Redirect URIs: http://localhost:8080/*
Roles:
admin
Users:
test-user
My authorization setup for admin-service-api is as follows:
Resources: Books Resource
Uri (these are my API endpoints):
/v1/books
/v1/books/{id}
Scopes:
books:delete
books:create
books:update
books:read
Policies:
Default Policy (probably not needed?)
Books Policy:
Realm roles:
admin (the required checkbox is not checked)
Permissions:
Default Permission (probably not needed?)
Books Resource Permission:
Apply Policy: Books Policy
So with this setup, I have restricted my API (which is written in GoLang) to only allow requests if the requesting user has the appropriate permissions by making a request to the Keycloak API via https://my.auth.server/auth/realms/{{realm_name}}/protocol/openid-connect/token to retrieve the users access token and a list of the users permissions.
From there I can use this access token to make requests to my API to create/read/update/delete books so long as my test-user has the admin role. If my user does not have the admin role, the user is presented with an unauthorized message (401).
Hi @mdelez , I realize now that I was thinking of a different feature. When @simonjcarr referred to “fine-grained authorization services”, I assumed he meant the experimental feature Fine Grain Admin Permissions, but I see now he just meant the basic Authorization services, which I didn’t realize Keycloak also referred to as “fine-grained” in their documentation and UI. My mistake.
You’re right, the Authorization tab is available only for Confidential clients. I don’t really know for certain, but I feel like this is a logical requirement. Authorization requires enforcement. If you enable Authorization, you’re expected to do policy enforcement in your application. You can’t securely do policy enforcement in a front-end application, because the user has complete access to your policy enforcement code.
I think if you wanted to “cheat”, you could use a Confidential client on the front end if you can find a Javascript OIDC adapter that allows you to specify the secret, though I suspect some do not to prevent this kind of insecure implementation.
If you want to “do it right”, I guess you need two clients. A public client for your front-end, and a confidential client for your back-end.
Not really an expert though: I’m just guessing that’s why this is the case.
Hi @sharpedavid, no worries about the confusion, I’ve come to realize that’s quite normal when working with Keycloak. Their documentation is extensive but at the cost of being confusing.
I’m currently trying the two clients method (actually I was last week but I’m still struggling). Currently I have my admin-service-api set up like it is above and I also have another client called “admin-ui” which is my frontend and this client has an access type of public. So with this, I can use the js-adapter to authenticate my user and I get an access token via https://my.auth.server/auth/realms/{{realm_name}}/protocol/openid-connect/token. Easy-peasy. The problem I’m facing, is how can I then use this access token to make requests to my API? Since my API is protected via a different client, if I use the access token I got from my admin-ui client, I am unable to retrieve a list of scopes that my user has access to via https://my.auth.server/auth/realms/{{realm_name}}/protocol/openid-connect/token
For obtaining the user’s scopes I use the endpoint above and this as the request body:
(content-type is x-www-form-urlencoded) grant_type: urn:ietf:params:oauth:grant-type:uma-ticket audience: admin-service-api response_mode: permissions
It’s clear to me that I should have one client for Authentication, which will be public and one client for Authorization, which will be confidential. What’s super unclear to me is how I can use these in conjunction with one another.
Hi @mdelez , I’m not an expert when it comes to the Authorization features of Keycloak using resources and scopes. I’ve enabled Authorization features to play around a bit, but I rely on role-based access in production.
For basic role-based access, my set-up looks like this:
Confidential backend client. Has roles A, B, C, D.
Public frontend client. Has no roles of its own, but in the “Scope” tab you permit the backend roles (alternatively enable “Full Scope Allowed”).
The user gets assigned roles for the backend client. When they authenticate with the frontend client, their token will include the backend roles.
Sorry if this isn’t helpful, but good luck. My advice is to avoid enabling Authorization unless you’re certain you want it. It’s much easier to get started with roles.
I eventually got it working but I wasn’t understanding how it was working so I switched to something similar to your set up. Perhaps I’ll revisit fine grained authorization one day but it sure is difficult to understand how it all works. Basic role-based access is much simpler to understand
