Does redhard provide Keycloak license ?
Keycloak is Open Source Software licensed under the Apache 2.0 license. There are no costs if you want to use the software, but there is also no support for Keycloak.
If you are looking for official Support from Red Hat, then you can buy a commercial support subscription and use the product called “Red Hat SSO”, which is completely based on Keycloak, but comes with support, an SLA and patches/fixes. At the same time, you have to fulfill the requirements (environment, database, etc.) on how to run RH-SSO to get support.
thanks dasniko for the reply. basically, i want to build a IAM solution using keycloak and do customization based on customer requirement. need dedicated support only on keycloak features - ex, keycloak authorization embedded with login page and i want to expose authorize api to external client separately and could it be possible ?
