Hi all,
I’m attempting to use Keycloak to support multi-tenancy within a SpringBoot 2 application using Spring Security.
I’m using
org.keycloak
keycloak-spring-boot-starter
9.0.0
org.springframework.boot
spring-boot-starter-security
2.2.5.RELEASE
To enable multitenancy I have a MultitenantConfigResolver
class which extends KeycloakSpringBootConfigResolver
. MultitenantConfigResolver
is loaded via my SecurityConfig
which extends KeycloakWebSEcurityConfigurerAdapter
This config resolver largely works as I expect. The target tenant is inferred from the issuer of the provided JWT on the Request. Then an AdapterConfig
is built and passed into the KeycloakDeploymentBuilder
.build(adapterConfig);
A key point I’m unsure is correct – when an unauthenticated request is made (no Authorization header), the resolve method of the MultitenantConfigResolver
returns null.
I have certain endpoints which I want to be publicly accessible. Those are all prefixed by /public.
In SecurityConfig
this is my HttpSecurity
configuration:
@Override protected void configure(HttpSecurity http) throws Exception { super.configure(http); http .csrf().disable() .authorizeRequests() .antMatchers("/public/**").permitAll() .anyRequest().authenticated(); }
I’m finding that even when calling an endpoint starting with /public/ my MultitenantConfigResolver
is still being called, and the endpoint is not called.
Of a lower priority, in this case instead of returning a 401, I get an empty 200, I’m not sure where to coerce the appropriate status code.
Complete code for both MultitenantConfigResolver
and HttpSecurity
are here: Full Keycloak Multitenant Configuration · GitHub
