I’m trying to switch to the new keycloak.x distribution (from 11.0.2).
Importing previous realm settings and porting the configurations worked mostly good, but i noticed that the realm auth urls have changed when switching to keycloak.x . The url for the OpenID authorization endpoint was “http://localhost:8080/auth/realms/master/protocol/openid-connect/auth”, but with keycloak.x, it is “http://localhost:8080/realms/master/protocol/openid-connect/auth” (notice the missing ‘auth’ at the begin).
I’m looking for a configuration option to change the url’s back the the “old” scheme, since there are other applications that do not work without the missing ‘auth’ at the begin. Is there a property or configuration i can set?
