I’m working on porting several extensions in a project to run in the new Keycloak.X Docker image. Is anyone aware of documentation specific to the differences in how to install extensions?
A couple of specific things I’m looking at:
Deploying modules. I used to put modules in /opt/jboss/keycloak/modules/system/layers/keycloak/foo/bar/main/foobar.jar and put the module.xml in /opt/jboss/keycloak/modules/system/layers/keycloak/foo/bar/main/module.xml. Now that this is gone? Where can I put modules?
Naming modules and expressing their dependencies. I used to build module.xml files that named the module and listed the dependencies. Where do I do that now?
EARs and third-party JARs. I used to build EAR files for extensions that required third-party JARs, and put those JARs in the lib directory of the EAR. It appears that EAR packaging is no longer supported. What is the recommended way to deploy extensions that require other libraries?
Would appreciate it if anyone has any guidance or templates. Thank you!
Most of the times I create fat jars (with maven shade plugin or similar) which contain all necessary dependencies for the provider.
I didn’t have any experience with something that is a “module” in Wildfly in Keycloak.X environments, yet. Have you tried to place your JARs into one of the Quarkus lib folders?
Thanks @dasniko. I will try the fat-jar route for packaging, and a few spots for module deployment.
The thing I don’t have the first idea of is how to name modules (in the jar manifest?) in a way that they will be reference-able by other extensions. I used to do it in the module.xml as <module name="org.foo.my-module"..., but I’m not sure how to get keycloak to recognize it as a module. Maybe the route is to just deploy it with each extension fat-jar.
In Quarkus there is no such thing like a „module“. It just has to be regular JAR which will be made available to the classpath. Once it is there, it should be available for a provider (and any other custom code).
I’ve got something working that I wanted to share here to see if anyone sees something wrong with it, or can benefit from how I did it.
Description of the “legacy” keycloak setup:
I have several extensions, packaged as jars, with overlapping 3rd party library and module dependencies
I package the extensions as an .ear file, which contains all the 3rd party library jars, and an application.xml describing contents
I build a docker image that
a. puts the modules in /opt/jboss/keycloak/modules/system/layers/keycloak/, each with a module.xml describing the name, contents and dependencies.
b. puts the .ear file in /opt/jboss/keycloak/standalone/deployments/
How I solved it for keycloak-x:
I still “build” an unpacked version of the .ear file from above.
a. puts the extension jars from the unpacked .ear in /opt/keycloak/providers/
b. puts the 3rd party library jars from the unpacked .ear in /opt/keycloak/lib/lib/main/
c. puts the module jars in /opt/keycloak/lib/lib/main/
Notes:
As @dasniko indicated, it’s not a container in the same way Wildfly was, so it basically just loads everything on the same classpath.
I avoid conflicts, and don’t require building multiple fat-jars, by placing common dependencies in the common lib dir /opt/keycloak/lib/lib/main/
Module dependencies that used to be placed in my extensions jar manifests as Dependencies seem to get ignored. As long as something is on the classpath, it seems to work.
I have only tested this from a cold start, in a docker image.
