Dear forum members
The customer is using a custom email solution to send emails via Keycloak. The original extension was based on Link To Tutorial which was working without any issues.
I have now upgraded the client to be Quarkus compatible but the solution doesn’t seem to work anymore. I have installed the extension in the quarkus based Keycloak (17/18). I can see in the logs that Keycloak has deployed it and initialized by the inlcuded factory but if I call it.
It seems that it will execute the DefaultEmailProvider.
The problem is probably that the EmailProvider is an internal spi therefore I would probably need to specify that I want to replace the default one. Sadly, there is no documentation about this.
How can I achieve it without compile Keycloak from scratch?
Thank you in advance.
