Hello guys,
i just downloaded and extracted keycloak-22.0.5 version on my windows 10 machine hardrdrive…
I did default configurations
And try to run command kc.sh -v build it gives below an error as below .
I checked there is no build-system.properties in that path: D:\KeyCloak\test\keycloak-22.0.5\lib\quarkus\build-system.properties.
but if i start server with
kc.sh start-dev it runs normally.
I am new in keycloak and searched for that kind of error but no luck.
Thanks.
ERROR: Failed to run ‘build’ command.
Error details:
java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.doReaugment(QuarkusEntryPoint.java:84)
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.doRun(QuarkusEntryPoint.java:48)
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.main(QuarkusEntryPoint.java:32)
at org.keycloak.quarkus.runtime.cli.command.Build.run(Build.java:81)
at picocli.CommandLine.executeUserObject(CommandLine.java:2026)
at picocli.CommandLine.access$1500(CommandLine.java:148)
at picocli.CommandLine$RunLast.executeUserObjectOfLastSubcommandWithSameParent(CommandLine.java:2461)
at picocli.CommandLine$RunLast.handle(CommandLine.java:2453)
at picocli.CommandLine$RunLast.handle(CommandLine.java:2415)
at picocli.CommandLine$AbstractParseResultHandler.execute(CommandLine.java:2273)
at picocli.CommandLine$RunLast.execute(CommandLine.java:2417)
at picocli.CommandLine.execute(CommandLine.java:2170)
at org.keycloak.quarkus.runtime.cli.Picocli.parseAndRun(Picocli.java:100)
at org.keycloak.quarkus.runtime.KeycloakMain.main(KeycloakMain.java:88)
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.doRun(QuarkusEntryPoint.java:61)
Caused by: java.nio.file.NoSuchFileException: D:\KeyCloak\test\keycloak-22.0.5\lib\quarkus\build-system.properties
at java.base/sun.nio.fs.WindowsException.translateToIOException(WindowsException.java:85)
at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:103)
at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:108)
at java.base/sun.nio.fs.WindowsFileSystemProvider.newByteChannel(WindowsFileSystemProvider.java:236)
at java.base/java.nio.file.Files.newByteChannel(Files.java:380)
at java.base/java.nio.file.Files.newByteChannel(Files.java:432)
at java.base/java.nio.file.spi.FileSystemProvider.newInputStream(FileSystemProvider.java:422)
at java.base/java.nio.file.Files.newInputStream(Files.java:160)
at io.quarkus.deployment.mutability.ReaugmentTask.main(ReaugmentTask.java:35)
… 24 more
