When I access the Keycloak login page, and click on administration console → Login into master realm
I believe this is for admin access and control into the whole Keycloak instance.
Inside I created 2 realms, c9 and shiru.
In a similar way, I want to log in as admin to c9 and shiru (so that later I can give the admin access to these realms to the respective tenants and then they can control and manage roles for their applications).
How can I achieve the same?
Thanks
Did you ever get an answer for this? It’s a good question, but there doesn’t appear to be a good out-of-the-box answer for it. Community: Anyone know the answer to this?? Basically want to be able to have a landing page for each Realm.
There is the account console for each realm hosted under https://<kc url>/realms/<realmname>/account/
and the individual admin console for each realm hosted unter https://<kc url>/admin/<realmname>/console
For the admin console you just need to assing the appropriate admin-console client roles to the respective users to manage that particular realm.
Thanks, @ThoreKr - - just over thinking it I guess.
