at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) |
at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:177) |
at java.base/java.util.Iterator.forEachRemaining(Iterator.java:133) |
at java.base/java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801) |
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) |
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) |
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) |
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) |
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) |
at java.base/java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:497) |
at org.hibernate.query.spi.StreamDecorator.forEach(StreamDecorator.java:153) |
at org.keycloak.utils.ClosingStream.forEach(ClosingStream.java:128) |
at org.keycloak.migration.migrators.MigrateTo20_0_0.migrate(MigrateTo20_0_0.java:19) |
at org.keycloak.storage.datastore.LegacyMigrationManager.migrate(LegacyMigrationManager.java:133) |
at org.keycloak.migration.MigrationModelManager.migrate(MigrationModelManager.java:33) |
at org.keycloak.quarkus.runtime.storage.legacy.database.LegacyJpaConnectionProviderFactory.migrateModel(LegacyJpaConnectionProviderFactory.java:219) |
at org.keycloak.quarkus.runtime.storage.legacy.database.LegacyJpaConnectionProviderFactory.initSchema(LegacyJpaConnectionProviderFactory.java:213) |
at org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:260) |
at org.keycloak.quarkus.runtime.storage.legacy.database.LegacyJpaConnectionProviderFactory.postInit(LegacyJpaConnectionProviderFactory.java:138) |
at org.keycloak.quarkus.runtime.integration.QuarkusKeycloakSessionFactory.init(QuarkusKeycloakSessionFactory.java:104) |
at org.keycloak.quarkus.runtime.integration.jaxrs.QuarkusKeycloakApplication.startup(QuarkusKeycloakApplication.java:42) |
at org.keycloak.quarkus.runtime.integration.QuarkusLifecycleObserver.onStartupEvent(QuarkusLifecycleObserver.java:37) |
at org.keycloak.quarkus.runtime.integration.QuarkusLifecycleObserver_Observer_onStartupEvent_b0e82415b143738dc1f986a5fa4668e83d0a5dea.notify(Unknown Source) |
at io.quarkus.arc.impl.EventImpl$Notifier.notifyObservers(EventImpl.java:326) |
at io.quarkus.arc.impl.EventImpl$Notifier.notify(EventImpl.java:308) |
at io.quarkus.arc.impl.EventImpl.fire(EventImpl.java:76) |
at io.quarkus.arc.runtime.ArcRecorder.fireLifecycleEvent(ArcRecorder.java:131) |
at io.quarkus.arc.runtime.ArcRecorder.handleLifecycleEvents(ArcRecorder.java:100) |
at io.quarkus.deployment.steps.LifecycleEventsBuildStep$startupEvent1144526294.deploy_0(Unknown Source) |
at io.quarkus.deployment.steps.LifecycleEventsBuildStep$startupEvent1144526294.deploy(Unknown Source) |
at io.quarkus.runner.ApplicationImpl.doStart(Unknown Source) |
at io.quarkus.runtime.Application.start(Application.java:101) |
at io.quarkus.runtime.ApplicationLifecycleManager.run(ApplicationLifecycleManager.java:110) |
at io.quarkus.runtime.Quarkus.run(Quarkus.java:69) |
at org.keycloak.quarkus.runtime.KeycloakMain.start(KeycloakMain.java:103) |
at org.keycloak.quarkus.runtime.cli.command.AbstractStartCommand.run(AbstractStartCommand.java:37) |
at picocli.CommandLine.executeUserObject(CommandLine.java:1939) |
at picocli.CommandLine.access$1300(CommandLine.java:145) |
at picocli.CommandLine$RunLast.executeUserObjectOfLastSubcommandWithSameParent(CommandLine.java:2358) |
at picocli.CommandLine$RunLast.handle(CommandLine.java:2352) |
at picocli.CommandLine$RunLast.handle(CommandLine.java:2314) |
at picocli.CommandLine$AbstractParseResultHandler.execute(CommandLine.java:2179) |
at picocli.CommandLine$RunLast.execute(CommandLine.java:2316) |
at picocli.CommandLine.execute(CommandLine.java:2078) |
at org.keycloak.quarkus.runtime.cli.Picocli.parseAndRun(Picocli.java:93) |
at org.keycloak.quarkus.runtime.KeycloakMain.main(KeycloakMain.java:89) |
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) |
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) |
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) |
at java.base/java.lang.reflect.Method.invoke(Method.java:566) |
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.doRun(QuarkusEntryPoint.java:61) |
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.main(QuarkusEntryPoint.java:32) |
