Hello everyone,
I’m in the process of integrating Firebase Authentication with Keycloak for my Angular application and have run into a problem regarding nonce validation between Keycloak and Firebase.
Context:
- Keycloak serves as my OpenID Connect (OIDC) provider, successfully returning an ID token after user login.
- Firebase is used for authentication following the retrieval of the ID token from Keycloak.
- My objective is to authenticate users with Firebase using the ID token obtained from Keycloak.
Here’s how I initialize Keycloak:
this.keycloak.init({
config: this.appConstant.keycloakConfig,
initOptions: {
onLoad: 'check-sso',
flow: 'standard',
pkceMethod: 'S256',
useNonce: true, // Keycloak generates a nonce internally
enableBearerInterceptor: true,
After a successful Keycloak login, I retrieve the ID token and attempt to pass it to Firebase for sign-in:
async signInWithFirebase(idToken: string): Promise<any> {
const auth = getAuth();
const provider = new OAuthProvider(environment.firebaseConfig.oidcProvider);
try {
const credential = provider.credential({
idToken,
// rawNonce: '<rawNonce>', // Initially not passing rawNonce
const result = await signInWithCredential(auth, credential);
return result;
} catch (error: any) {
console.error(error, 'Firebase sign-in error');
Issues Encountered:
- When I do not pass the
rawNonce
: I receive the following error from Firebase:
FirebaseError: Nonce is missing in the request. (auth/missing-or-invalid-nonce)
- When I try passing the
rawNonce
that I decoded from the Keycloak ID token: I get this error instead:
FirebaseError: Firebase: The nonce in ID Token "<hashed_nonce>" does not match the SHA256 hash of the raw nonce "<rawNonce>" in the request. (auth/missing-or-invalid-nonce).
This indicates that while Firebase is now recognizing the presence of a nonce, there is a mismatch between the hashed nonce in the ID token and the rawNonce I provided.
Questions:
- Is there a way to access the raw nonce generated by Keycloak that matches the hashed value in the ID token?
- Can we configure Keycloak to accept a custom rawNonce that we generate and pass along to Firebase for validation?
- What is the recommended method for resolving the nonce mismatch issue when using Keycloak as an OIDC provider with Firebase?
- Would relying solely on PKCE (without utilizing a nonce) be a secure alternative in this scenario?
I have attempted to enable PKCE (pkceMethod: 'S256'
) in the Keycloak configuration, but Firebase still insists on requiring the nonce. Any assistance or guidance on this issue would be greatly appreciated!
Thank you in advance!
