Problem setting up Docker-Compose Keycloak MySQL
Hello Everyone!
I’m struggeling with the deployment of Keycloak with a MySQL Database.
The Keycloak server does boot up but the browser does not get a response.
version: '3.9'
services:
  mysql:
    image: mysql:8.0
    restart: unless-stopped
    ports:
      - 3309:3306
    environment:
      MYSQL_ROOT_PASSWORD: root
      MYSQL_USER: keycloak
      MYSQL_PASSWORD: keycloak
      MYSQL_DATABASE: keycloakPreformatted text
    networks:
      migration-keycloak-and-mysql-network:
        ipv4_address: 192.168.1.2
  keycloak:
    image: quay.io/keycloak/keycloak:23.0.4
    user: root
    environment:
      KEYCLOAK_ADMIN: admin
      KEYCLOAK_ADMIN_PASSWORD: admin
      KC_DB: "mysql"
      KC_DB_URL: 'jdbc:mysql://192.168.1.2:3306/keycloak'
      KC_DB_USERNAME: root
      KC_DB_PASSWORD: root
      KC_Hostname: localhost
      KC_HTTPS_KEY_STORE_PASSWORD: secret
    entrypoint: /bin/bash
    command: -c "cd /opt/keycloak/conf && keytool -genkeypair -alias localhost -keyalg RSA -keysize 2048 -validity 365 -keystore server.keystore -dname 'cn=Server Administrator,o=Acme,c=GB' -keypass secret -storepass secret && cd ../bin/ && ./kc.sh show-config && ./kc.sh start  --log-level=INFO --hostname=localhost"
    ports:
      - 8080:8080
    networks:
        ipv4_address: 192.168.1.3
    depends_on:
      - mysql
networks:
    ipam:
      config:
        - subnet: 192.168.1.0/24
          gateway: 192.168.1.1
What am I doing wrong?
Thanks a lot!
Ali
Hi Ali
There are different errors in your docker compose file:
  • mysql container:
    • mysql port mapping: should be 3306:3306
    • MYSQL_DATABASE: keycloak
    • KC_DB_USERNAME: keycloak
    • KC_DB_PASSWORD: keycloak
  • keycloak container:
    • when running keycloak with https, you should also map the port 8443:8443
Then I found out, that there is a timing issue. So just depends_on mysql is not enough. Instead, I implemented a health check found here: A better Docker MySQL heathcheck | Strangebuzz.
This ends up in this modified docker compose:
version: '3.9'
services:
  mysql:
    image: mysql:8.0
    ports:
      - 3306:3306
    environment:
    healthcheck:
      test: ["CMD-SHELL", "mysqladmin ping -P 3306 -proot | grep 'mysqld is alive' || exit 1"]
      interval: 10s
      timeout: 30s
      retries: 10
    networks:
  keycloak:
    user: root
    environment:
      KC_DB: "mysql"
    ports:
      - 8080:8080
      - 8443:8443
    networks:
    depends_on:
      mysql:
        condition: service_healthy
networks:
    ipam:
      config:
There are still many things in this compose file that looks strange to me, but at least it is working when accessing keycloak with https://localhost:8443/ with these modifications.
Kind regards, Stefan
