Greetings all,
I’m trying to deploy 20.0.3 alongside our production keycloak instance (older version) we’re deploying everything in kubernetes. I’ve got a seperate DB configured and all the authentication/access worked out forthat, also I’m using different ports from our production instance, however the deployment fails, and goes into CLBO.
The logs from the deployment show the following:
2023-02-13 14:26:37,418 WARN [org.infinispan.statetransfer.InboundTransferTask] (jgroups-9,devkeycloak-66f67f6c9d-7slwg-2994) ISPN000210: Failed to request state of cache authenticationSessions from node keycloak-6944c8bf7b-fn5d4-16218, segments {0-255}: org.infinispan.commons.CacheException: ExceptionResponse(java.io.EOFException)
at org.infinispan.statetransfer.InboundTransferTask.lambda$startTransfer$3(InboundTransferTask.java:167)
at java.base/java.util.concurrent.CompletableFuture.uniHandle(CompletableFuture.java:930)
at java.base/java.util.concurrent.CompletableFuture$UniHandle.tryFire(CompletableFuture.java:907)
at java.base/java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:506)
at java.base/java.util.concurrent.CompletableFuture.complete(CompletableFuture.java:2073)
at org.infinispan.remoting.transport.AbstractRequest.complete(AbstractRequest.java:67)
at org.infinispan.remoting.transport.impl.SingleTargetRequest.onResponse(SingleTargetRequest.java:46)
at org.infinispan.remoting.transport.impl.RequestRepository.addResponse(RequestRepository.java:51)
at org.infinispan.remoting.transport.jgroups.JGroupsTransport.processResponse(JGroupsTransport.java:1496)
at org.infinispan.remoting.transport.jgroups.JGroupsTransport.processMessage(JGroupsTransport.java:1398)
at org.infinispan.remoting.transport.jgroups.JGroupsTransport.access$300(JGroupsTransport.java:146)
at org.infinispan.remoting.transport.jgroups.JGroupsTransport$ChannelCallbacks.up(JGroupsTransport.java:1586)
at org.jgroups.JChannel.up(JChannel.java:780)
at org.jgroups.stack.ProtocolStack.up(ProtocolStack.java:913)
at org.jgroups.protocols.FRAG3.up(FRAG3.java:165)
at org.jgroups.protocols.FlowControl.up(FlowControl.java:347)
at org.jgroups.protocols.pbcast.GMS.up(GMS.java:876)
at org.jgroups.protocols.pbcast.STABLE.up(STABLE.java:254)
at org.jgroups.protocols.UNICAST3.deliverMessage(UNICAST3.java:1048)
at org.jgroups.protocols.UNICAST3.addMessage(UNICAST3.java:771)
at org.jgroups.protocols.UNICAST3.handleDataReceived(UNICAST3.java:752)
at org.jgroups.protocols.UNICAST3.up(UNICAST3.java:405)
at org.jgroups.protocols.pbcast.NAKACK2.up(NAKACK2.java:592)
at org.jgroups.protocols.VERIFY_SUSPECT.up(VERIFY_SUSPECT.java:132)
at org.jgroups.protocols.FailureDetection.up(FailureDetection.java:186)
at org.jgroups.protocols.FD_SOCK.up(FD_SOCK.java:254)
at org.jgroups.protocols.MERGE3.up(MERGE3.java:281)
at org.jgroups.protocols.Discovery.up(Discovery.java:300)
at org.jgroups.protocols.TP.passMessageUp(TP.java:1400)
at org.jgroups.util.SubmitToThreadPool$SingleMessageHandler.run(SubmitToThreadPool.java:98)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
2023-02-13 14:29:36,458 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000080: Disconnecting JGroups channel `ISPN`
2023-02-13 14:29:36,645 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to start server in (production) mode
2023-02-13 14:29:36,645 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to start caches
2023-02-13 14:29:36,645 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) For more details run the same command passing the '--verbose' option. Also you can use '--help' to see the details about the usage of the particular command.
Has anyone experienced this, are have I created a unicorn?
Thanks!
