React front end, keycloak 21.0.2,
added the cancel button to custom login ftl. The code
<#import “template.ftl” as layout>
<@layout.registrationLayout displayMessage=!messagesPerField.existsError(‘username’,‘password’) displayInfo=realm.password && realm.registrationAllowed && !registrationDisabled??; section>
<#if section = “header”>
${msg(“loginAccountTitle”)}
<#elseif section = “form”>
<#if realm.password>
<#if !usernameHidden??>
<#if !realm.loginWithEmailAllowed>${msg(“username”)}<#elseif !realm.registrationEmailAsUsername>${msg(“usernameOrEmail”)}<#else>${msg(“email”)}</#if>
                    <input tabindex="1" id="username" class="${properties.kcInputClass!}" name="username" value="${(login.username!'')}"  type="text" autofocus autocomplete="off"
                           aria-invalid="<#if messagesPerField.existsError('username','password')>true</#if>"
                        <span id="input-error" class="${properties.kcInputErrorMessageClass!}" aria-live="polite">
                                ${kcSanitize(messagesPerField.getFirstError('username','password'))?no_esc}
                        </span>
                    </#if>
                </div>
            </#if>
            <div class="${properties.kcFormGroupClass!}">
                <label for="password" class="${properties.kcLabelClass!}">${msg("password")}</label>
                <input tabindex="2" id="password" class="${properties.kcInputClass!}" name="password" type="password" autocomplete="off"
                <#if usernameHidden?? && messagesPerField.existsError('username','password')>
                    </span>
                </#if>
            </div>
            <div class="${properties.kcFormGroupClass!} ${properties.kcFormSettingClass!}">
                <div id="kc-form-options">
                    <#if realm.rememberMe && !usernameHidden??>
                        <div class="checkbox">
                            <label>
                                <#if login.rememberMe??>
                                    <input tabindex="3" id="rememberMe" name="rememberMe" type="checkbox" checked> ${msg("rememberMe")}
                                <#else>
                                    <input tabindex="3" id="rememberMe" name="rememberMe" type="checkbox"> ${msg("rememberMe")}
                                </#if>
                            </label>
                        </div>
                    </#if>
                    </div>
                    <div class="${properties.kcFormOptionsWrapperClass!}">
                        <#if realm.resetPasswordAllowed>
                            <span><a tabindex="5" href="${url.loginResetCredentialsUrl}">${msg("doForgotPassword")}</a></span>
                        </#if>
                    </div>
              </div>
              <div id="kc-form-buttons" class="${properties.kcFormGroupClass!}">
                  <input type="hidden" id="id-hidden-input" name="credentialId" <#if auth.selectedCredential?has_content>value="${auth.selectedCredential}"</#if>/>
                  <input tabindex="4" class="${properties.kcButtonClass!} ${properties.kcButtonPrimaryClass!} ${properties.kcButtonBlockClass!} ${properties.kcButtonLargeClass!}" name="login" id="kc-login" type="submit" value="${msg("doLogIn")}"/>
              </div>
        </form>
     <#-- The below form and div lines is added for dtsc relam login page -->
           <form id="kc-form-cancel" onsubmit="login.disabled = true; return true;" action="${url.loginAction}" method="post">
              <input tabindex="7" class="${properties.kcButtonClass!} ${properties.kcButtonPrimaryClass!} ${properties.kcButtonBlockClass!} ${properties.kcButtonLargeClass!}" name="cancel" id="kc-cancel" type="submit"   value="${msg("doCancel")}"/>
             </div>
             </form>
    </#if>
    </div>
</div>
<#elseif section = "info" >
    <#if realm.password && realm.registrationAllowed && !registrationDisabled??>
        <div id="kc-registration-container">
            <div id="kc-registration">
                <span>${msg("noAccount")} <a tabindex="6"
                                             href="${url.registrationUrl}">${msg("doRegister")}</a></span>
            </div>
        </div>
    </#if>
<#elseif section = "socialProviders" >
    <#if realm.password && social.providers??>
        <div id="kc-social-providers" class="${properties.kcFormSocialAccountSectionClass!}">
            <hr/>
            <h4>${msg("identity-provider-login-label")}</h4>
            <ul class="${properties.kcFormSocialAccountListClass!} <#if social.providers?size gt 3>${properties.kcFormSocialAccountListGridClass!}</#if>">
                <#list social.providers as p>
                    <a id="social-${p.alias}" class="${properties.kcFormSocialAccountListButtonClass!} <#if social.providers?size gt 3>${properties.kcFormSocialAccountGridItem!}</#if>"
                            type="button" href="${p.loginUrl}">
                        <#if p.iconClasses?has_content>
                            <i class="${properties.kcCommonLogoIdP!} ${p.iconClasses!}" aria-hidden="true"></i>
                            <span class="${properties.kcFormSocialAccountNameClass!} kc-social-icon-text">${p.displayName!}</span>
                        <#else>
                            <span class="${properties.kcFormSocialAccountNameClass!}">${p.displayName!}</span>
                        </#if>
                    </a>
                </#list>
            </ul>
        </div>
    </#if>
</#if>
/@layout.registrationLayout
The problem if i click Cancel button it is not going to client’s root url. If I click login with correct credentials it is going to the correct url. I wanted the Cancel button during the logging.
