Redundant connection to Keycloak
Hello.
I have two instances of Keycloak running with a shared database and ispn cache for redundancy.
I then have a web client app implemented in Spring Security which works fine when I configure it to go either against instance 1 or instance 2 of Keycloak.
Now I want the web client app to be able to fail over to instance 2 if instance 1 of keycloak goes down.
My first idea was to implement some dynamic failover configuration in the web client app but that seems to require a lot of custom code which I want to avoid.
The other idea was to hide the Keycloak instances behind a load balancer and use the Spring Cloud components like gateway, discovery and the load balancer.
I tested that solution but I’m having problems getting it to work.
I know it is maybe a bit outside of the Keycloak domain but what are the best practices here, how do people implement redundant connections to Keycloak?
You can’t do failover with different user facing domains. A load balancer has to distribute the traffic to one or both instances.
Otherwise sessions, Passkeys and TOTP Tokens will break in spectacular ways, because they are domain bound.
99.999% of IdP deployments use an LB
And the guy that runs the other 0.001% just got fired. :rofl:
Thank you guys for your input.
Please forgive my limited understanding of the cache/clustering handling in Keycloak but I tried to put my view into a sequence diagram.
According to this page [ Keycloak Cluster Setup - Keycloak ] both instances must share the same database.
And according to this page [Configuring distributed caches - Keycloak] the sessions should be distributed among the cluster entities.
So by introducing a load balancer a user could authenticate via instance 1 and get a refresh token form instance 2 ?
I tried to illustrate the flow in the sequence diagram below but steps 1 to 24 is the login phase while steps 27 to 33 is the token refresh.
Is this correct?
