I configured several tenants on the same Keycloak deployment, and I cannot figure out what is misconfigured with one of them.
I am using the Direct Access workflow.
When I ask for a token generation I correctly obtain a new access token, alongside the refresh token. In this case every token has its own expire time at the maximum allowed.
"access_token": "...",
"expires_in": 300,
"refresh_expires_in": 1800,
"refresh_token": "...",
"token_type": "Bearer",
"scope": "openid profile email"
Then, when I perform a token refresh I correclty obtain new tokens. But what I see is that the refresh token expiration time (field refresh_expires_in) is not resetted but continue to decrease in time, request after request.
My expectation is the new refresh token has the maximum time availability.
In the following refresh response refresh_expires_in is 1582, but my expectation is 1800 (30 minutes, as specified in my configuration).
"expires_in": 300,
"refresh_expires_in": 1582,
Thank you for your support,
Nicola
