If I define the target_claim to my_attr and regex pattern to 1test it works, but when I would like to check the 2test I have no idea how to do it . Do you know any solution?
Iād recommend to ask the maintainer of the extension directly in the mentioned GitHub repo as a new issue or discussion thread.
AFAIK Sven-Torben is not a member here in this forum.
