Hi, please, how do I set the maximum username length to 30 characters during registration and disable illegal characters
Thank you
Thank you
package com.mkyong.regex.username;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
public class UsernameValidator {
// simple regex
//private static final String USERNAME_PATTERN = "^[a-z0-9\\._-]{5,20}$";
// strict regex
"^[a-zA-Z0-9]([._-](?![._-])|[a-zA-Z0-9]){3,18}[a-zA-Z0-9]$";
private static final Pattern pattern = Pattern.compile(USERNAME_PATTERN);
public static boolean isValid(final String username) {
Matcher matcher = pattern.matcher(username);
return matcher.matches();
Something like that, I just don’t know where to put it
Declarative User Profile might be your friend.
It’s still a preview feature, you’ll have to enable it in the config.
Then, this should be possible without any coding.
See docs for details.
Thank you very much
