I currently writing a custom REST Provider and ideally the interface should only be available at a specific realm. Is there any solution to achieve this?
Thank you,
Tobias
Thank you,
Tobias
Not that I know of. I have had this requirement before, and I just hard coded the realm in my implementation and just returned a 403 for any access for another realm.
Thanks for your fast response. After a little bit of research I also found a similar approach. Instead of hard code it into the provider itself, you can make the distinction in the “create()” - method of the factory. It’s now looks something like this:
@Override
public RealmResourceProvider create(KeycloakSession keycloakSession) {
var realm = keycloakSession.getContext().getRealm();
if(realm.getName().equals("YourRealm")){
return new CustomResourceProvider(keycloakSession);
return null;
Keycloak itself returns a “404” if you make a request on any other realm.
