probably I missed some elementary config handle, but does Keycloak allow to set the OIDC token issuer for a given realm?
Example scenario
Keycloak instance lives at:
https://kc.example.com
Realm test is at
https://kc.example.com/auth/realms/test
The OIDC Issuer is:
Is it possible to customize the issuer set in tokens, to be, for instance:
https://test.example.com
This would assume that a reverse proxy is deployed in front of the keycloak instance
to map requests for
https://test.example.com/.well-known/openid-configuration
to
https://kc.example.com/auth/test/.well-known/openid-configuration
Thanks for your help!
