Running multiple services with docker compose on various backend URL using nginx.
Here is the configuration for keycloak
location /auth {
proxy_pass http://keycloak-container:8080;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $server_name;
Attached the image:
Getting the following response:
Request URL: https://qa.XXX.com/auth/realms/master/protocol/openid-connect/login-status-iframe.html/init?client_id=account-console&origin=https%3A%2F%2Fqa.XXX.com
Request Method: GET
Status Code: 403 Forbidden
Remote Address: 45.77.144.143:443
Referrer Policy: no-referrer
when hitting the endpoint on browser. Getting the above response
