Support for id_token_hint to avoid login flow again
Does keycloak support id_token_hint?
If user is already authenticated on keycloak auth server, and on click of some link within the system, if Authorization needs to happen again for the same user on auth server, can we somehow bypass login flow?
I am trying to use prompt=none and passing id_token_hint value with previously received id_token from auth server and session_state value received earlier, but that’s giving me login_required error from keycloak on the app redirect url when getting authorization code.
Here’s the example URL:
http://keycloak:9080/auth/realms/igia/protocol/openid-connect/auth?
client_id=sagar-test
&redirect_uri=http%3A%2F%2F127.0.0.1%3A9010%2Fcallback
&response_type=code
&scope=openid+launch
&state=bbb
&prompt=none
&session_state=894b7695-de61-4cd0-b1d0-9509ae65fd0d
&id_token_hint=eyJhbGciOiJSUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICJlYlZwVmkyaVV5anpXWTVaWHMzRE80b3RZaVJibDJpbE11N3BrYXo5RWpJIn0.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.Yqi0N7ilYsr_fP_-7qWiTDbaiLTBRbW3p-w07D33w8LbIbhqxRHAi5FYwcYOo5HQffcjmcRetYUHBSExVpyRl0YrHON6_g02x1UJurMZPwGbDiTRMf4_xiRvDM18TnZuQEGCvN0s8xtm5wqv2jKqWSyRD6RktYZKuLssaH-wp20nryBTRv87M6-Nh1MfHa4m-Xv5nw4t_y6LWNPurwGUZRwsPGAIxeN8anFjxdf4kYUQD44etc4y1ZijZZ8lCWoSW4RWSblM7iaalqdjsVqx7fUeTXTpRptZJZiasaqT7O08Z2lN1zsA4sFHc8UgFqvIKq_2tExnNAI1A4FwGh-Kpw
Any help is appreciated!
I would be interested in this as well, specifically for the use case of not having to log in again in the account console
I’m also interested in knowing whether Keycloak is supporting this as per OpenID Connect specification.
OpenID Connect requires that if the ID token is sent encrypted by the OP, the ID token has to be re-encrypted by the client app, with its own key shared with the OP. So an additional question, is whether Keycloak allows to use the client secret for this purpose.
Regards,
Hi there I’m interested as well in understanding if prompt=none&id_token_hint= is supported by Keycloak.
In the documentation if found a mention only in logout section Securing Applications and Services Guide
